Aside from a rattle and some carb issues (running after car is shut off, smell of gas) the van was running fine. I took it in for an oil change, and now the engine cuts out (dies). Mostly in idle, but also when I'm driving down the road.
At the shop they said a screw attaching the carb to the engine fell out, and also that I need to replace/rebuild the carb (Carter YT). Hope this makes sense. I'm no mechanic, so I'm wondering if they are legit or not. Does this kind of thing happen a lot? Thanks in advance.
