by Digz Sun Apr 26, 2009 6:00 am
If I can toss something in here, On the kit I got it supplies shims to adjust the caliper bracket in or out what I think would be 1/4 of an inch one way or the other because the axle flange is a fixed point, Kit bracket mounts on the inside, The caddy bracket on the outside, the goal of the shims is to make the outer pad lightly contact the outward face of the rotor. Not being able to move the caddy bracket inwards one would have to move the rotor outwards or move the axle flange in. Or,,, and I havent measured the hieght of the my rotors yet,, find a rotor that is not as tall. I will measure the kit rotors today , I am curious myself if they are also a knock off of the caddy rotors as are the calipers in the kit
