Hey all I have been watching this forum for over a year wanting to buy a E-100 to make into a work van, we like to be different than other companies. Found one thx to this forums constant updates of what is out there and just got it out here 2 weeks ago. Got it for $3K and runs like a top short of basic valve cover oil leak, oil pan leak, could use a set of points,and previous owner said the float level on the carb needs adjusting?...new to carbs since I build import tuners so not sure what that's all about. all that being said I used to be a ford tech for a dealer years back so I can do 90% of my own work in my garage. looking for a few answers to get me rolling and then some suggestions.
questions
A. the steering box has some play in it, id say about 3 inches side to side before it actually turns the wheel... is that normal or how would I go about cleaning that up?
B. bushing in front end look ok and the previous owner was a "front end" guy... but the passenger front wheel hops a bit or has some slight play... my passenger in the van says it feels like its going to fall off... im thinking its the wheel bearing??? thoughts? still has front drums.
C. this van is going to be loaded with 300-400 lbs of equipment...should i upgrade to the disc breaks in the front even though the front breaks literally just got done before i bought it?
D. looking into doing wheels and tires ASAP and then maybe lowering it with air bags soon after (not too low just tucking tire) looks like 15x7 is the preferred size? what offset would you recommend?cant post link for a few more days since im "new member"
recommendations
1.need ideas for airbags or lowering that will be good for daily driving. safety is key since its a work van.
2. is there a good HID head light conversion you would recommend?
3. any more ideas to make this thing a head turner for business?
The over all plan is to spend less than $6k more on it to make a rat rod style work van in white black and orange (my company colors) and draw attention to the van every where we go so people will want to look at it and call us up over the other companies in the area.
Thanks all. ill keep everyone posted with pics on progress
questions
recommendations
