by donivan65 Tue Mar 12, 2013 7:39 pm
A wire from the left rear tail light goes to it,,,,,also there should be a ground wire coming from that light back through those holes to the van body,,,,,the wire is probably brown,,,,there should be a connector where the wire splits off from the tail light and sneaks out through those 2 holes in the door and the post to get to the license light,,,,,both rear tail lights and that license light use the same wire,,,,,,
