Has anyone found a kit or does anyone have any advice for how I can change at least my front drum brakes to disc brakes? I would like to do front and rear, but I will settle for front only if need be.
Drum to Disc Brake Conversion
Re: Drum to Disc Brake Conversion
Short answer, yes. Use search.
CraigK- Number of posts : 141
Like Thundervan said, using the search feature will turn up lots of good and different ideas.
Check out this site for front disc kits
www.dddiscbrakes.com
Craig
Craig
jadedstem- Number of posts : 22
Registration date : 2010-05-30
Yeah i got d and d disc set..I also got the priviledge to meet with old skool (vic is a member) and he has a really cool kit as well...I like..I also believe fmc 56 (fred is a member)has one too..All of them work and all three people are good people to deal with...happy braking
Murdock- Number of posts : 313
I have a Scarebird setup myself, in fact he used my van to prototype his bracket. There are also different master cylinder setups to choose from. Searching this site will give you a nauseating amount of information, with pictures, on the topic.
Sorry about the "short answer" post this morning. I was at work and couldn't spend time on the VV. If you don't convert to disc you could upgrade to the heavy duty 10x2 1/2" drums front and rear, if you don't have them already. They work well until you run through water. If you go disc, plan on spending some $$$, but it will be money well spent. Good luck and happy vanning!
