    Gas tank for 72 GMC half ton?
    Gas tank for 72 GMC half ton? Empty Gas tank for 72 GMC half ton?
    Post by Guest Thu Dec 13, 2012 10:15 am
    I've got a 72 GMC half ton vandura (gen 3?) with a (very) rusty gas tank. I've used every ounce of google-fu I have, but can't seem to locate a replacement fuel tank.
    Any suggestions? Are ones from some later (or earlier!) year compatible (perhaps with some hand-built mounting HW)? I want to get this thing back on the road, before the spiders claim it for their own.
    Thanks, Steve
    Number of posts : 512
    Gas tank for 72 GMC half ton? Empty Re: Gas tank for 72 GMC half ton?
    Post by pan58head Thu Dec 13, 2012 10:47 am
    Steve any tank from 71-95 should fit. In about 1987 they went to fuel injection so the tank has a different baffle inside. There where two different sizes 22 and 33 gallon. Last time I check on ebay they where under $100 without the sender, that runs about another $100. How about pick a part in california, no luck bob
    Post by Guest Thu Dec 13, 2012 11:25 am
    Hmmm... Thats what I originally figured, but when I look at tanks from later years online ,the dimensions always seem to be different than the existing tank. for example, all the tanks I find seem to be 12" deep while mine seems to be only 10.5" deep or so. I haven't found a tank that seems to be the same dimensions as what I've got. I don't need an exact match, but I figure it does need to fit in the existing space, leave proper ground clearance and have filler tube line up "close enough".
    steve
    Post by pan58head Fri Dec 14, 2012 5:34 am
    Mars I have a 22 gallon tank out and on the floor post you sizes and I will measure mine. post a picture ? bob
    Post by Guest Fri Dec 14, 2012 8:55 am
    pan58head wrote:Mars I have a 22 gallon tank out and on the floor post you sizes and I will measure mine. post a picture ? bob
    Mine is currently still in the vehicle, so the picture may not be that helpful. Is there something specific I should try to take a picture of?
    The tank dimensions are 26" for and aft X 29" side to side (to the outside of the welded flange) the tank looks to be about 10" or 10.5" tall. (Certainly not the 12" I read for the GM8A tank design). The tank has 3 ports on the left side. The fill looks to be 1-3/8" diam and is centered 10" ( 9.75"?) forward from rearmost edge of the flange. It looks like there is a diagonal "bite" designed into the top front edge of the tank to provide clearance to a transverse rib under the floor.
    There is also a vent right next to the fill, and another vent forward. (I'm guessing that is another vent and the actual pickup is in the top center of the tank with gage). I don't see the forward vent on e.g. the GM8a. This is a 1972 (gen 3?) from Calif so I wonder if it's "special" for smog somehow... (However, it's old enough that I don't have to get it smog inspected anymore, hooray!)
    Thanks for looking. Another compatibility datapoint would be helpful.
    steve
    Gas tank for 72 GMC half ton? Img_2812
    Post by pan58head Tue Dec 18, 2012 5:03 am
    Mars I'll try to get some pictures today bob
      Current date/time is Fri Nov 22, 2024 1:03 am
