anyone know were i can find a driveshaft boot, mine is torn and leaking grease, i thought maybe someone had this problem before and knows what to use as a suplement boot if the original ones arent available any more, thanks for any help,
driveshaft boot
driveshaft boot
Re: driveshaft boot
for my trunnion boot, i took the part at robert motor parts, i wanted to change to a yoke, but went the least expensiv for now, someday.
www.robertsmotorparts.com
or call 800-231-3180
Re: driveshaft boot
thanks man, i appreciate your help.
Re: driveshaft boot
On a side note, my local driveline shop wants $175 to cut the shaft and fit in a slip joint and modern U-joint. Depending on how much the boot costs you it might be an option?
It's on my list of things to do.
Re: driveshaft boot
i might try a new boot untill the slip joint goes bad then have it changed over to a u joint, i have a good drive shaft shop in town for when ever i need to, thanks guys for the help,
