+8
vanman2
Stoopid john
Schoessow
12 posters
My 1969 Dodge Van project
Schoessow- Number of posts : 16
Registration date : 2012-07-30
- Number of posts : 8729
Re: My 1969 Dodge Van project
looks good welcome to v . v.
Stoopid john- Number of posts : 265
Very cool, welcome! What engine is in it?
Welcome fellow west coaster, great looking Dodge A100. I love those wheels.
Space Truckin- Number of posts : 1279
Very nice ride, WELCOME!!!
Welcome! Nice looking A108 you got there, keep us posted on the progress with her!
Big W- Number of posts : 3282
Welcome to VV. Great looking ride.
vanman2- Number of posts : 73
Registration date : 2012-06-09
Welcome to V V , nice looking ride
the ole girl is lookin good, WELCOME to VV
A 108 on Cragars? Cool!
Welcome!
Welcome!
Rod, I like this van! The color and the Rat Fink style graphics are way cool. I know I'm way ahead of myself but I have some graphic ideas in mind also.
Re-insulated the inside of the dog house today. Should make it a little quieter. Tomorrow try and see what is wrong with the gas gauge. The fun never stop's. Dennis
O.H.surfboards- Number of posts : 58
Welcome! And that's a great lookin van, can't wait till mine is back on the road. Hoping a couple more months.
Rod, what size wheels and tires are they and will the fronts fit over disc brakes? i want some wide cragars on the rear and skinny tires up front, i plan on putting disc brakes on soon i dont think these 14'' wheels i have now will fit over calipers, thanks in advance, john
Schoessow regarding the gas gauge at the back of the van center of the fuel tank is the flote were the steel tube comes out and goes into a rubber hose and back to a steel tube again there should be a jumper clamp from steel tube to steel tube if it is missing the gauge will not work. you could test it with a coper wire if the steel lines are cleaned...
dodge man wrote:Rod, what size wheels and tires are they and will the fronts fit over disc brakes? i want some wide cragars on the rear and skinny tires up front, i plan on putting disc brakes on soon i dont think these 14'' wheels i have now will fit over calipers, thanks in advance, john
15X8 and 15X10
dix wrote:Schoessow regarding the gas gauge at the back of the van center of the fuel tank is the flote were the steel tube comes out and goes into a rubber hose and back to a steel tube again there should be a jumper clamp from steel tube to steel tube if it is missing the gauge will not work. you could test it with a coper wire if the steel lines are cleaned...
dix, thanks for the tip. Yes I have the clip in place. I removed the clip and cleaned the tubes and the clip and replaced it. I removed the sending wire, grounded it to the frame in hopes the gauge would move, but it did not. So, more testing to come. I'm thinking it would be more productive to replace the gauge and the sending unit. After 43 years all the gauges should be replaced I'm thinkin.
if you are not in a hurry a sending unit / flote can be found on e-bay for $50.00 in a hurry $100.00 make sure you put thenm side by side and bend the flote rod to match the existing one.. make sure you have a good ground..
Schoessow wrote:dix wrote:Schoessow regarding the gas gauge at the back of the van center of the fuel tank is the flote were the steel tube comes out and goes into a rubber hose and back to a steel tube again there should be a jumper clamp from steel tube to steel tube if it is missing the gauge will not work. you could test it with a coper wire if the steel lines are cleaned...
If you go with aftermarket gauges:
The amp gauge is a source of fires. Even though I like having a amp meter, you may want to jump that out and install a voltage gauge. The temperature gauge uses a resistance wire somewhere between the cluster and the sensor (location unknown) so would want to run a new wire to the doghouse.
- Post n°19
itruns wrote:Schoessow wrote:dix wrote:Schoessow regarding the gas gauge at the back of the van center of the fuel tank is the flote were the steel tube comes out and goes into a rubber hose and back to a steel tube again there should be a jumper clamp from steel tube to steel tube if it is missing the gauge will not work. you could test it with a coper wire if the steel lines are cleaned...
Itruns, Thanks for the info. My ole service buddy John Walther that has a auto repair shop told me the same thing.
