How can you tell if your engine is a 250 or a 230 My numbers on the side of the block say it could be either
230 or 250
teamthunder7- Number of posts : 13
Registration date : 2012-02-17
230 or 250
64chevy- Number of posts : 364
Re: 230 or 250
Since the bore is the same on both blocks you have to measure the stroke. 3.25 for a 230 and 3.50 for a 250.
VANagain- Number of posts : 1048
Re: 230 or 250
Could you get an accurate measurement of stroke by putting a piece of coat hanger thru a spark plug hole and manually turning the engine over and measuring how much the wire goes up and down? Probably tricky since the wire would be at an angle.
Re: 230 or 250
They make cubic inch measuring tools. They are used in racing classes where racers are limited to a certain size engine.
http://www.precisionmeasure.com/test1.htm
