Today I decided to tackle my starter, starter solenoid and alternator.
Starter solenoid and starter were changed without skipping a beat, easy.
Alternator another story. I removed the gen and obviously there is a size difference between the gen and alt. I was able to bolt on with the stock brackets but the alternators pulley does not line up with the other pulleys. Off by 1/2-1".
I either need to fab up some brackets or buy some pre-made. Which brackets did you use when making your swap from gen to alt?
