+4
andrew carter
8 posters
MASTER bricoleur A-100 8 doors
Re: MASTER bricoleur A-100 8 doors
Welcome to the site! Looks like a great project.
Vanish- Admin
- Number of posts : 5155
Yes WELCOME IN !!!! GREAT LOOKING VAN !!!!!
,,,Vanish,,,
MCMLXV
andrew carter- Number of posts : 465
Registration date : 2011-09-04
welcome to the site great looking dodge keep the pics coming love to see the progress
Very Nice van!!!! Thanks for the pic's
Nice Work!!!!
Nice job on the repairs. I have to fix the same area on my roof and your pictures are going to be real helpful when I start on that section.
Nice work & welding - ill add something too- when ever u weld anything Thats galvenized - & het that bad smell taste in the mouth - drink some milk -it will go away!!= an old welders trick!
That's zinc poisoning. Better to have a fan blow the yellow stuff away!
http://www.finishing.com/85/35.shtml
Also, do not weld on anything that has been cleaned with common aerosol cleaners. The fumes will kill!
http://www.brewracingframes.com/id75.htm
You did a great job there, had to be a pain to clean up that weld in a small area like that
Nice work,Mstr.Your patch repairs look great.As mentioned above,that galvanized material is pure voodoo to work around.Grind that away,using a mask before welding.
I will add...it must be nice to have tile flooring in your garage. Pretty cool !
whopman- Number of posts : 387
SCHWEEET !
