by donivan65 Sat Jul 02, 2011 3:56 pm
We did not like the way the evaporators stuck out from under the dash, so we went with one that has the heater core built in it,,,,,,,in that way, it kind of just replaces the whole heater system in our vans. We got remote switches so they don't have to go under the dash to run the A/C and Heater. And we did not want to add a condenser in front of the radiator so we went with one that has an electric fan on it that you can mount anywhere, like under the van. Any compressor will work,,,,,those Sandens are common,,,,,,It comes with all the hose and fittings,,,,,,the critical part is how to mount the compressor and the belt to drive it. On the 350 engine, they provide a bracket to move the alternator and another one to mount the compressor. Now I would like to know if they have a 6 cylinder bracket set up. All the other parts look like its the best system for our vans. But we shall see IF these parts will fit the van without too many problems........and it's a Hot Rod System,,,,,,,you know that means it SURELY costs more than a system that is not for the rich Hot Rodders,,,,,,,,
