+5
kltcustoms
9 posters
this is widowmaker
this is widowmaker
[url=http://www.servimg.com/image_preview.php?i=9&u=16552535][img]https://i.servimg.com[img]https://i.servimg.com/u/f25/16/55/25/35[url=https://servimg.com/view/16552535/12]/100_3621.jpg[/img][/url]/u/f25/16/55/25/35/100_3618.jp[img]https://i.servimg.com/u/f25/16/55/25/[url=https://servimg.com/view/16552535/12]35/100_3621.jpg[/img][/url]g[/img][/url]
kiwimopar- Number of posts : 745
Re: this is widowmaker
Cool looking van Marty
I can't see the pic's
kltcustoms- Number of posts : 199
Registration date : 2008-07-07
G-Man wrote:I can't see the pic's
HAHA
I can see them now??? Bad A$$ van
very nice!
I really like the exhaust and the hand prints on the windows.
Big W- Number of posts : 3282
Nope that ass looks just fine. "I'd tap that"...GAS PEDAL THAT IS...lol. Oh ya very nice look'n van you got there.
That's one wild shifter lever Marty I like it a lot ...and welcome to the madness
wylee- Number of posts : 917
very cool ride...........................
thanks for all the feedback guys, i'm stuck in china till july 3rd then i'll be on the road again, i got some parts ordered, and i want to start on the rest of the interior, the front seats are already recovered in red vinyl with gray inserts i want to do the back with 2 matching buckets, red and gray vinyl and diamond plate alumimium and a killer sound system, i also need to paint the steering wheel and the tach. housing, i'll paint them red metalflake, heavy on the flake, let me know what ya think, yea or nay ?
Do it
69 a 100- Number of posts : 142
Registration date : 2009-01-03
how did you narrow the rear end and what size tires are those?
and what motor is in that
Stoopid john- Number of posts : 265
If you wear rings, i wouldn't paint the steering wheel. I had a painted wheel in the past and it didn't take long to wish i had left it alone.
I'd love to see a picture of the rear suspension. Cool ride
john
john
- Post n°19
it's got a built 440 in it, i narrowed the housing had the axles resplined, moved the springs inboard of the frame on new crossmembers that i made, i'm running 31x15.5x15 mickey thompson tires. john i've flaked wheels in the past using a flat base coat, mix your flake in a clear midcoat, then top it all of with 4 or 5 coats of urethane enamel clear coat, holds up real well
oo3- Number of posts : 290
- Post n°20
is that console between the front seat just a console - or did you open up the area for more air into the doghouse ? - oo3
- Post n°21
yea ,i opened up the floor to get more air to keep her cool
- Post n°22
so can you still remove the front of doghouse cover? - or do you even need to ? - i can imagine airflow is even more important with a 440 than a slant six! - oo3
- Post n°23
yea i made the console or as i call it the air tunnel to be removeable, its bolted in, then i can remove the front cover, but you dont need to the rad installs from the bottom
- Post n°24
if you moved the leaf springs in where did you put the gas tank?
- Post n°25
i got to looking around my garage and i spotted a vw beetle tank that looked just right, the shape of the bottom clears the springs, the top half of the tank is above the floor, vw sending unit works the dodge gauge, same ohm rating, i welded the new filler tube in and removed the old tube, in the future i'll fabricate a new top half for it to try to get at least 20 gallons in it
