finally got my van back together today. it had the 250/6 intagrated head, and exhaust was cracked. swapped it to original type head and had it decked 60/1000. compression should be 9.6:1 now. bigger cam fell in while it was apart. comp cams 268 duration, 219 @ 50, and .529 lift. also installed headers but wont be keeping them, they hang too low. cleaned and painted everything while apart, fixed a few wires and got 'most' of the stuff in doghouse straightened out. looks much better and runs great. lot more power, starts easy, slight lope at idle but none of the problems you get with a bigger cam. headers will have to stay for a little while but glasspacks are coming off this weekend.
headers, cam and decked head
Re: headers, cam and decked head
Dont forget the zinc oil additive
its in there
SMART!!!!
hywaychild- Number of posts : 389
Registration date : 2008-05-27
what was wrong with the headers?? how low is your van ? like to talk to you about it before i do mine ? 870 2583050 are send me your number i will call you jay
headers are about 4" - 5" from ground, they dont drag and have no problems yet and was on gravel roads last night but they could easily of fit 6" higher. i bought them to go on a 292 but put them on the 250. only 2" difference. it did create a problem with mount but was easily corrected. john 724 312 0285. afternoon or evenings.
