This info is off of wikipedia, what is the difference between the 67 to 72 170 HP motors and the rest that decrease HP to as low as 117 HP in the 1980 engine? and how hard or what needs to be done to make any of these engines equal in HP, or do you only look for certain year engines and stay away from the rest ? researching for a torque motor with good drive-ability and good MPG, that is reliable, for auto overdrive trans and transfercase to put into 4X4 van and tow small pickup truck bed trailer behind it. Do not want to have to put a bunch of after market hi po parts into it to make it perform. Want to use as many swappable parts for performance as possible, 240 head, efi header exhaust,,cam, later maybe throttle body injection, stuff like that. Do not want to bore out big, hi compression pistons and rods or porting heads, if can get away with it. A cruiser not a racer, I am easy on the throttle control don't need to tear the drive-train up. Or is the 240 the way to go? Thanks
300 CID Straight-6 1967–72 170 hp (130 kW
300 CID Straight-6 1980 117 hp (87 kW) 227 lb·ft (308 N·m) 1bbl
300 CID† Straight-6 1980 120 hp (89 kW) 229 lb·ft (310 N·m) 1bbl
300 CID Straight-6 1981–86 122 hp (91 kW) 255 lb·ft (346 N·m) 1bbl
4.9 L I6 1987–91 165 hp (123 kW) 275 lb·ft (373 N·m) EFI
4.9 L I6 1992–93 145 hp (108 kW) 265 lb·ft (359 N·m)
4.9 L I6 1994–96 150 hp (110 kW) 260 lb·ft (350 N·m)
240 CID Straight-6 1965–66 150 hp (110 kW)
240 CID Straight-6 1967–72 150 hp (110 kW
240 CID Straight-6 1973–77 no ratings
300 CID I6 1973–79 no ratings
