In the process of installing the rear and side cargo doors after sandblasting. Im installing the doors off of a 68 on the 67 body. The doors which look identical dont want to line up properly, seem to be out of square. As there is hardly no adjustment in the in the hinges im not sure how to make this work. Any suggestions?
BADBADGER
A100 cargo door fit
A100 cargo door fit
Re: A100 cargo door fit
When I put my 69 Chevy together after paint I had the same problem. You just have to mess with it more. It make it easier if you have a friend help with holding the door and also someone else may see what has to be done you may be missing
blackace- Number of posts : 450
G-Man wrote:When I put my 69 Chevy together after paint I had the same problem. You just have to mess with it more. It make it easier if you have a friend help with holding the door and also someone else may see what has to be done you may be missing
Hum sounds like G-Man is offering his services. Must need a road trip
69 a 100- Number of posts : 142
Registration date : 2009-01-03
i noticed that when i put my doors back on they didnt seem to line up correct. i just bent them to fix right
Could the mis-alignment be due to some sort of body sag once the doors are removed? Don't have any but just wonder if something like that could be doing this.
Yes - maybe just having to take care of alignment problems- this can be a pain Too. You said they were sandblasted- If done at a large commercial blasting company???? I have seen parts become warped by heavy sand blasting?? I wouldnt think so yet ive seeb this - sanf creates friction and will warp things if done heavily.
I did all of the sand blasting myself. the parts dont have any warpage too them. Possibly having the body on jack stands for a long time may have something to do with this problem. Wheels and tires are in so after they are on Ill drop it to the ground and see if it makes any difference.
- Number of posts : 8759
Try hanging both doors in the inside leave the bolts a little lose .Close the doors .Then from the out side move them around till the gaps are even all around.Then start to tighten them down. you will most likley need to shim them with a thin peice of metal. You can use thin washers to adjust them to were you want them. As you tighten them you have to watch what happens to the gaps. Once you get them close tighten them down. And then you have to go back and move them and shim them to get them just right. It takes some time to get them were you want them. Some times you need to walk away and think about it and come back at it later. Remember they all are 40 pluss years oud they never were perfect. .I hung mine then installed the gasket and readjusted them again after that. Don't try to rush it. It will only piss you off....
