+6
back2thewoods
10 posters
miata seats
miata seats
Hello all, anybody have a set of miata seats , I need a measurement. I need to know how wide they are at the back where the bottom and back meet, also how how wide the backs are. I installed a supercharger on my 1st gen and have very little room for a seat on the passenger side. I only have 16" hoping the miata seat will work. I've check the junk yards but none have any to measure Thanks Bob
Re: miata seats
19 1/2 " where they meet because of hinge cover, brackets are 13" center to center 18 1/2 wide back
DanTheVanMan- Commissioner
- Number of posts : 7905
Re: miata seats
back2thewoods- Number of posts : 842
Re: miata seats
just got a set last weekend for mine, anybody have pics of bracket install in 1st. gen. chevy, thanks
Re: miata seats
Thanks back to the drawing board I only have 16-17 inches Bob
Lyrad- Number of posts : 277
Registration date : 2011-01-20
Re: miata seats
Crap EH! you might have to go with Smartcar seats. lol What does that supercharger look like? great idea, how the al did you do that.
Re: miata seats
Smartcar... Hmmmm, we refer to them as "Smart-Coffins" down here...
Re: miata seats
B2W,
Will take some pic's in the next day or two and post them for you.
Dan
Dan
Re: miata seats
Lol ok Thanks
m1dadio- Chevy Guru
- Number of posts : 1778
Re: miata seats
Re: miata seats
I put a set of chevy venture van second row seats in my 68 g10
they are the narrowest seats that I could find and they were 17.5 wide
and they were a challenge to install also sit high, so not the answer for
everyone.
everyone.
Big W- Number of posts : 3282
Re: miata seats
Just curious...but are the Venture driver and pass front seat even wider? cus that's what I was going to use in my Econo.
Re: miata seats
yes they are wider than the middle and rear seats, probably 21/22 inchers.
just not sure how much room you have in an e van
Re: miata seats
back2thewoods,
Here's a few pic's I found from when I was trying to figure out the Miata mounting.. Once I figured it out I permanently mounted them and they are fully functional!
Using 2" square stock to make crossbar. Cutting to length, drilling a mounting hole using outside factory seat mount.
Made inside brackets using 1 3/4" stock to fit inside above crossbar and mount to doghouse.
Took this pic while testing the bar and bracket for proper length only. I have the doghouse bracket in sideways, normally it would be up and down following the bodyline of the doghouse. But you get the idea......
Position your seats on the bars so you can use both the sliders and reclining functions of the seats. Mark and drill the holes and mount the fronts of both seats and then work on the backs.
On the backs, make the tubes & brackets Driv & Pass sides are different lengths. Position the rear brackets and mark the seat mounting holes first and drill, then work on the outside (Fender well) mountings. This takes a bit more creativity since the do not line up with the factory seat mounting holes. You can use a few large fat washers or make some custom brackets like I did. Then just bolt the inside brackets to the doghouse..... Done!
Fully adjustable and reclining! Oh, almost forgot.... You can "OPEN" your doghouse lid without hitting the seats if you position the seats just right.
Hope this helps....
Dan
Hope this helps....
Dan
toad- Number of posts : 355
Registration date : 2010-05-30
Re: miata seats
I have early model Sprinter seats. Had to take off the arm rests, but they don't look bad. toad
Re: miata seats
VERY CLEAN INSTALL THANKS, DAN
Re: miata seats
ANY PICS OF BACK BRACKETS?
Re: miata seats
Their Identical to the fronts except for they are offset from the fender well by about an inch so you need a spacer. Large washers work great....
Dan
Dan
- Post n°19
Re: miata seats
got ya, thanks again
- Post n°20
Re: miata seats
finally, got to install miata seats today, dan thanks for pics. guided me right through installation. they fit great!!
- Post n°21
Re: miata seats
Anything to help. Glad you got them in.....
Dan
Dan
- Post n°22
Re: miata seats
- Number of posts : 2016
- Post n°23
Re: miata seats
Looks like a good deal on some Miata seats with local pick-up only in PA.
http://www.ebay.com/itm/1996-96-MAZDA-MIATA-MX-5-MX5-RIGHT-LEFT-FRONT-REAR-SET-OF-SEATS-SEAT-TAN-OEM-/190684888307?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c65b47cf3&vxp=mtr#ht_500wt_945
