    i need help
    i need help Empty i need help
    Post by Guest Tue Mar 15, 2011 4:45 pm
    im having this problem with the jeep, and im concerned it might lead to something worst. i know its not a van, but i have to ask the experts for some help before i take it to the shop.
    when i started the jeep today i had to hit the 'starter relay' a few times for it to start. and when running i hear this 'ratcheting' noise.
    i also notices a jumper cable where im sure it should not be. and also a crack on the relay, here are some pics, thank you guys. i really apreciate it.
    i need help Dscn5210
    i need help Empty Re: i need help
    Post by Guest Tue Mar 15, 2011 4:51 pm
    i need help Dscn5211
    i need help Dscn5212
    i need help Dscn5213
    Post by Twinpilot001 Tue Mar 15, 2011 5:18 pm
    yup- change the starter solenoid that all is hooked to - someone has the alligator clips powering something and the other one is on the Ground??? cable possible- needs to be redone properly. The cause of having to hit that solenoid is a coroded contact inside that u cant repair -- just get a ned solenoid & change it -putting all back like it was & try it . Then if all is good - re-do those wires properly
      Current date/time is Fri Nov 22, 2024 3:09 am
