I just installed a fuel sending unit, got the one from ebay for 50. Looks nice and does work but I have just under 1/4 tank of fuel and it registers 3/4. Better than nothing I guess. I adjusted it as good as I could, pretty much to the limit and it still reads high. The original connector is gone so I put a eye on the wire and connected it with the nut, does the original connector make a difference? I know it was a push on. The guage seems to be working, when I disconnect the wire it goes off so I know the wire is not grounded somewhere.
What I was going to to is get some type of a resistor and put it in line, just find one that gets it down to 1/4 and see if when I fill it it shows full. I have had the guage apart and do not see a way to calibrate it besides bending something but if that is what should be done.
Any insight would be appreciated.
Thanks
Doug
Thanks
Doug
