First off, I have a '66 240cid with 4.00 9" rear end. I think I want a 3.25 ratio, but I'd like a second, third, opinion before I blow $600.
I did little mileage calculation, which was made harder to do since my speedo is off by a few miles. Starting at a gas station where I just filled up, I did mix driving, a little city, but mostly highway. Charted my route on googlemaps and compared the miles to my odometer readings and determined my correction factor. 1 odometer mile = 1.137 actual miles. I filled up at my end point and used this volume to determine the gas consumed. Sparing the boring details, I got 14.7mpg.
Now, when on the highway, the van cruises comfortably at 57 mph (actual). It feels strung out at 70mph (actual speed). It will go a little faster, but not much. So I figure, if I'd like to be able to cruise comfortable at 70mph, then I would need the final drive ratio reduced by a factor of 57/70 = 0.814. I have a 4.00 so, 4.00*0.814 = 3.26. So, this points me toward getting a 3.25.
Yesterday, I was just about to buy a rebuilt positrac 9" 3.25 rearend, and I thought, man, I really better double check that I actually have a 9" ford rear end. So I crawled under the van. Sure enough, it looks exactly the same, then I noticed the tag. It reads: WCR-S1, 3.00 7HE 787.
I can only assume the 3.00 means a 3.00 ratio... it must be an old tag?
It was quite a while ago when I checked the ratio... I did it when I was changing my clutch. This is what I think I did: with one rear wheel touching the ground, and the other up in the air, I turned the yoke until the wheel made one revolution. The number of turns of the yoke was 2. So if both wheel had been turning, I would have had to rotate the yoke 4 times to get them both to turn 1 rev... so I have 4.00. Right?
