blackace
dashing around
wylee- Number of posts : 917
dashing around
Re: dashing around
That would be cool. Good luck, heck of alot of cutting.
How thick is the metal??
Re: dashing around
its a hair thicker than the dash. i used air sheers to cut the out side.for the inside? gotta work on that..........
blackace- Number of posts : 450
Re: dashing around
I would think you could use a hole saw to get the main part of the material out and then use your air sheers to trim out the rest. Just match up the proper radial size hole saw for the corners and it should not be to bad. The turn signal area will be the most difficult area. Don't know if you have any machine shops around you but they could possible mill out the smaller areas for you fairly cheep.
Just my thoughts.
Just my thoughts.
Re: dashing around
Id try an air saw or maybe an assortment of sharp cold chisels or both, maybe leave enough extra to roll the edges like a slim 1/8" to help stiffen it up ? Use tape as a guide. Its cool stuff and its fun to try stuff like that, good luck with it.
Re: dashing around
Would be nice to be able to press the raised shape back into the new sheet metal, but that also requires tools and a decent press.
Always cool to have fun with stuff like this.
Re: dashing around
Re: dashing around
The dash is so bright, you gotta wear shades!
https://www.youtube.com/watch?v=meRgT5Nmogw
Re: dashing around
Lookin Good!
Re: dashing around
Is that pattern cut into that metal???
Re: dashing around
yes that pattern is cut in the metal., dont know much ware or what type it is but its cool looking............G-Man wrote:Is that pattern cut into that metal???
