Somewhere in all our posts I believe I came by someone using a corvette power steering application on a g10 van?? Help me find it please-Thanx
Post of some power steering info??
m1dadio- Chevy Guru
- Number of posts : 1778
THANX!! Thats what im lookin for =)
tilt column & power steering?
seems with this mod - were still using the origiona; steering box & column?? What also has been used for a tilt column in our 1st & 2nd gev vans -chev-GMC??
Bear- Number of posts : 849
thoughts on 4x4 conversions power steering? useing the k5 set up
i got the gear box with the axles would i beable to incorp it in a 2nd van and get power steering?? i havent looked my self just throwing it out there
m1dadio- Chevy Guru
you need to check the box to see which direction the gears turn.
Find the set up made by Sparky. its a good job of an integral box install
M1D
M1D
never though about that. thanks m-1
Thanx to Both -now to find sparky hehe
m1dadio- Chevy Guru
Re: Post of some power steering info??
ya I never thought of it either and paid $75 for a box I couldn't use.
The later G vans and Astro vans have a box that goes the right way. You need to find onw that has a short pitman shaft so you drag link stays close to the frame. I think Astro van box in the mid 90's was lookin good.
And you will have to either search or weld up a pitman arm for the job. I think sparky commented on pitman arm length. Pay attantion to that detail
M1D
M1D
was thinking of p.s. when i test drove the van. both wrists are shot so p.s. is a must. i had considered using a rack, coupled to tie rod ends and fabricating an arm and linkage to connect to steering box. havent measured or checked to see what all is in the way so just thinking outloud but seams way simpler and cheaper. BIG to do list before i evan crawl under and look but it will have p.s. next winter.
i,m with you on that both my shoulders are shot f-ed rotator cuffs tears.i to was thinking on the rack/pinion deal even got one from a dodge caravan for mock up. but one of our members told me it can,t be done.he told me why but i can,t rember anymore why.
my 'easy' solutions usually end up like that. if you remember why, please let me know. i am way to stuborn to just accept it cant be done without a reason. the other way looks like a lot of time and money. a kit sure would be nice.
joyrde- Number of posts : 26
Registration date : 2009-03-12
bumpbug- Number of posts : 147
Anybody look at these to put in the steering shaft between steering wheel and steering box ? some buggy guys were using them. you don't need the rack box you already have a steering box on the van.
http://www.howeperformance.com/images/products/charlynn.jpg
http://www.appletreeauto.com/images/P/17-2560.jpg
Char-Lynn® Torque Generator
Steering
Description Type PDF Literature ID
Char-Lynn ® torque generators have been completely redesigned to meet the needs of the changing market place. These torque generators providing power assist for steering, also eliminating the large hand wheels on gate valves, and providing powerful rotary motion with effortless manual rotary input on numerous other applications.
Today's market includes power steering on electric lift trucks. Char-Lynn® torque generators have been designed with features that greatly improve the operator's comfort as well as the vehicles performance. The increase in port surface area allows for the additional port requirement for units with:
217 Series Geroter Unit
Displacement
cm3/r [ in3/rev] Output
Torque
nm [lbf-in]
at 70 bar [1000 psi] Recommended Flow
lpm [gpm] Max. Operating Speed
(at 70 bar [1000 psi]
76
[4.7] 62
[550] 11,4
[3] 125
96
[5.9] 79
[700] 32,2
[3.5] 118
160
[9.7] 124
[1100] 13,69
[5] 102
227 Series Geroler® Unit
Displacement
cm3/r
[ in3/rev] Output
Torque
nm [lbf-in]
80
[4.9] 69
[608] 11,7
[3.1] 125
102
[6.2] 86
[760] 15,1
[4] 118
160
[9.7] 131
[1160] 18,9
[5] 102
Catalog
English
C-STOV-MC001-E1 Rev. 9/06
Steering Control Units catalogue Russian
Char-Lynn Power Steering, Torque Generator 207-XXXX-001 and -006
Parts English C-STTQ-TP001-E
Supersedes 06-318
Rev.10/91
Char-Lynn 217 Series and 227 Series Torque Generator -002
Parts English
C-STTQ-TP002-E
Supersedes 06-324
Rev.11/96
Char-Lynn 217 Series and 227 Series Torque Generator -002 Repair English C-STTQ-TS001-E
Supersedes
07-312
Rev.11/96
Char-Lynn Torque Generator, 227 Series -002
64499-000 Seal Kit (Quad Seal)
Installation Information English C-STTQ-TI001-E
Supersedes 04-350
Rev. 12/98
Steering
Displacement
Torque
nm [lbf-in]
76
[4.7] 62
[550] 11,4
[3] 125
96
[5.9] 79
[700] 32,2
[3.5] 118
160
[9.7] 124
[1100] 13,69
[5] 102
Displacement
cm3/r
[ in3/rev] Output
Torque
nm [lbf-in]
80
[4.9] 69
[608] 11,7
[3.1] 125
102
[6.2] 86
[760] 15,1
[4] 118
160
[9.7] 131
[1160] 18,9
[5] 102
Catalog
English
Supersedes 06-318
Rev.10/91
Parts English
C-STTQ-TP002-E
Supersedes 06-324
Rev.11/96
Supersedes
07-312
Rev.11/96
Supersedes 04-350
Rev. 12/98
