The pic is a little fuzzy but this is where they attached the motorcycle cable to the rod from the accelerator right after it went through the radiator support.
The motorcycle cable ran from there up to the home-made adjuster and attached to the carb linkage.
I replaced that setup with a five foot Jeg's push-pull cable and quick connect end fittings. The Jeg's setup looks a whole lot cleaner and I can't believe how much smoother the throttle operates. It's like driving a different van. Total cost for the cable and end fittings was a little over $100 and I had to fab some brackets to hold the cable but it was well worth it.
Next on the list is to clean up the doghouse wiring and a three wire alternator, along with giving that greasy 283 a bath.
