My recently acquired econoline pickup had a small exhaust leak when I bought it...no biggie I thought...I already had to pull the head on the magic bus cuz the exhaust manifold bolts were siezed up inside the exhaust manifold and several snapped off...all just to change the exhaust manifold gasket... an $8.49 part. Probably spent 6-8 hours fixing that one..
So I investigate and sho nuff.. the exhaust manifold is leaking...so I pull it and yep, its got bad spots in the gasket so i proceed to install a new gasket and button it up...Im all stoked up and hit the key...various retarded obnoxious noises and a loping rough barely running engine..along with a long deep moaning sound inside the carb when you tried to accelerate.. engine died..hit the key again, basically same nonsense...engine won't run...wont even idle...keep in mind it ran ok before I installed an exhaust gasket...well...me wasnt born last night and Ive seen plent of stupid stuff in my life...so I sniff maybe the exhaust pipe or muffler may be blocked internally so I take it off and....
BINGO!!
I cleaned it all out and now it runs fine.... Anybody wanna guess what that stuff is? Ill give you a hint..this truck has had some mice crawling around and wreaking havok on some wiring and some other stuff.....
BINGO!!
