    top of the block question!
    Hamilton
    Hamilton
    Number of posts : 95
    Registration date : 2010-07-06
    top of the block question! Empty top of the block question!
    Post by Hamilton Wed Jul 21, 2010 4:54 am
    hey all!!
    ok, so out changing the thermostat and noticed 2 things. What is this open hole in the block for? Looks like a cap could screw in there?
    top of the block question! Image001
    and also, this toward the front of the block and just to the side of the thermostat housing, it appears to be a plug into the top of the block, a brown wire coming off and into a cluster of wires, excuse the foil and birds nest in the above pic, I intend to clean that up, eeash!
    top of the block question! Image002
    thanks in advance everyone!
    Hami
    Number of posts : 3046
    top of the block question! Empty Re: top of the block question!
    Post by RodStRace Wed Jul 21, 2010 7:44 am
    The first hole is also visible in the second picture, and appears to be a blind hole. Probably a mounting point for a bracket, my guess would be for an A/C rear bracket. There will be others like this at the rear, for the coil mount.
    The second one is the opening for the temp gauge sending unit. It goes into the crossover for the coolant below the thermostat.
    Both of these are actually in the intake manifold, not the block.
    There are also wire clips on the right side valve cover. The wiring for the temp gauge and the alt are in a loom that goes in those.
    Here's a pic of mine BEFORE....
    top of the block question! DSCF1435
    Hamilton
    Hamilton
    Post by Hamilton Wed Jul 21, 2010 7:48 am
    aha! makes total sense Rod! I had a feeling that was temp but wanted to confirm. And yes, manifold, not block! Oops! thanks for the info!!
    Number of posts : 1148
    Post by jkr Wed Jul 21, 2010 2:21 pm
    and remember the wire from the tempature sending unit is a resistance wire.so don't cut into it or throw it away.
    Hamilton
    Hamilton
    Post by Hamilton Wed Jul 21, 2010 2:25 pm
    nope, no cutting, it works!
    if anything, I thought of reinforcing it. It appears to be weak from being moved around and might need a little electrical tape where it connects in to the sending unit.
      Current date/time is Tue Nov 19, 2024 5:16 am
