Well, my side doors rattled something terrible and the gaps were bad.
The guide at the top of the door was loose. It is like a plate that's spotwelded inside the door, and then has a three-sided pocket that slips into some slots on that plate. Then it is somehow crimped to hold it tight and keep the door pin guided properly and quietly. I found that the crimped part was loose. It would be easier to access this from the exterior surface of the door, but my welding skill isn't quite up for that yet... I went from the interior.
I quickly welded it up, totally not finished work.
When studying the gaps, I realized that the problem seemed to be with the upper hinge... there was a bulge in the exterior sheet metal at the upper hinge, and the gap at the top was non-existant. Then the front and rear door didn't even overlap... could see daylight through there really bad. It was hard to determine how the pillar was constructed or where it was damaged. And I couldn't fit a jack to push it out. Decided to cut and figure out what was up with the pillar from the outside. I realized that the pillar was also somewhat distorted! So through my access hole, I was able to straighten it out. Pillar didn't budge though. Finally, my brother showed up and immediately knew how to position the jack to work the pillar. To my surprise, a scissor jack fit perfectly, and I watched my brother tweak the jack and even out the gaps! Tonight it sits with the jack in place, a little beyond square Awesome!
Also then. to the back door, where the broken hinge that previously existed had contributed to the rear panel being badly dented.
Also, this corner has a rustout in the floor, and a suspect pillar. So I cut it open for enough access to the floor, and ultimately had to cut away the base of the pillar. At least I now know how the pillars are constructed. Towards the exterior, they are bent in a u-shape. Toward the interior, the panel that covers the pillar is relatively flat with the edges just curled around. There is a plate made of thicker gauge that the lower hings bolts to, and is sandwiched between the front and back plates. It was loose, and made access to the hinge bolts tricky. So, first I have to make the outer pillar, and then the floor. Anyway, this pillar was distorted and rusted.
I used my Dremel to cut these patches out... very tiny gaps for welding! More to come later (I have a couple holes in my van... gotta get er dun!)
Last edited by sasktrini on Mon Jun 14, 2010 10:50 am; edited 1 time in total (Reason for editing : missing block of text)
