Anybody on here try converting to a rack and pinion set up for your powered steering?
Thanks,
Thanks,
. Hey dan could you post a pic or two of how looks. I was thinking of doing that same thing, and what rack did you end up using...and did you have to by longer tie rod ends for it to work?....thanks.dan nachel wrote:I just put rack n pinion on my 64 E100. I mounted it to the axle. I used a "v" gearbox from an isuzu rodeo, and a slip shaft between the two. It is not power but works great.
