    1950 Pontiac tail lights?
    1950 Pontiac tail lights? Empty 1950 Pontiac tail lights?
    Post by Guest Mon May 03, 2010 6:24 pm
    Has anyone installed these?
    http://www.speedwaymotors.com/1950-Pontiac-Red-Taillight-Assembly,3079.html
    Is it direct fit plug and play?
    My bulb sockets are rotten and I can't find a replacement.
    1950 Pontiac tail lights? Empty Re: 1950 Pontiac tail lights?
    Post by G-Man Mon May 03, 2010 7:27 pm
    VB had them on this van, and said they take just a little modifieding to work
    Post by Guest Mon May 03, 2010 8:30 pm
    They are an exact same size as our Econo lenses. They mount differently is all. You can drill a couple of holes in the bezel and then use chrome screws to mount them.
    Post by Guest Tue May 04, 2010 6:07 pm
    Thanks,
    Any info on original bulb sockets?
    fmc56
    fmc56
    Number of posts : 553
    Post by fmc56 Wed May 05, 2010 11:36 pm
    I have a few non rusted ones, wires may be a bit hard though.
    Fred
    Number of posts : 437
    Registration date : 2010-12-14
    Post by StuNami Fri Feb 04, 2011 4:41 am
    Got any pics of them installed or being installed?
    Old Skool
    Number of posts : 1306
    Post by Old Skool Wed Feb 16, 2011 7:35 pm
    1950 Pontiac tail lights? 093110
    Good friends ride I helped with,,,
    vic
    Hellfish
    Number of posts : 146
    Post by Hellfish Sun Jul 03, 2011 7:14 pm
    I installed a Speedway set in my '65. After about 9 months sitting outside, they are still in decent shape, but there are a few hints at chrome problems.
    Anyway, I installed them but cutting out the "frame" that the original Econo buckets bolted to, and drilled some new holes. That was about it. So, if you need the buckets or the frames, let me know
      Current date/time is Fri Jan 24, 2025 1:11 pm
