    postal jeep question
    postal jeep question Empty postal jeep question
    Post by Guest Tue Feb 23, 2010 9:32 am
    maybe this could be applied to any car with leaf springs
    there is this jeep for sale and im interested.. in the description it says that it might need a left leaf spring..
    if in the case that i do get that vehicle is it possible to change, use, one from another vehicle?
    i guess what im saying is that are the leaf springs interchangeable with vehicles..
    what do i need to look for?
    lenght, widht? thickness? or.....
    its a postal jeep.. 81dj5
    gracias
    Number of posts : 1135
    postal jeep question Empty Re: postal jeep question
    Post by benwah Tue Feb 23, 2010 10:16 am
    As long as it's not the main carrier spring and the spring width is the same should work out ok. pretty ez. I have swapped whole leaf springs and pearches off newer trucks to older trucks, just due to the difficulty finding good pearches, shackles, ect... thats a bigger job. A thicker spring means a stiffer ride, 3/4 1 ton. Hope this helps.
    Post by Guest Tue Feb 23, 2010 6:22 pm
    A DJ5 uses the same springs as the CJ does. DJ just denotes right hand drive postal body.
      Current date/time is Fri Nov 22, 2024 2:41 am
