mattimuss
    Trans Mount
    mattimuss
    mattimuss
    Number of posts : 205
    Trans Mount Empty Trans Mount
    Post by mattimuss Wed Dec 23, 2009 8:36 pm
    Anyone out there know what the part# is for a 69 A108 trans mount, 318/727?
    Thanks!
    Matt
    Number of posts : 8729
    Trans Mount Empty re tranny mount
    Post by dix Sun Dec 27, 2009 6:57 am
    I am working on a part number for you hang in there. unless you allready have the mount taken care of dix...
    mattimuss
    mattimuss
    Trans Mount Empty Re: Trans Mount
    Post by mattimuss Sun Dec 27, 2009 9:54 am
    Holding......
    Post by dix Sun Dec 27, 2009 1:25 pm
    this may take a day or 2
    Number of posts : 917
    Post by wylee Mon Dec 28, 2009 5:34 am
    i need one also....
    Number of posts : 1148
    Post by jkr Mon Dec 28, 2009 4:55 pm
    george gessinger. he has the replacement bushings to press into the loops. they are a little different because they don't have the metal band around the outside like most replacement bushings. i got one from him 9 years ago and its still there and in good shape. just got to be creative to install it. two flat pieces of metal with a threaded rod through the center and draw the bushing in place. once it starts it goes in pretty easy.
    he's in Tamaqua Penn.
    company name us. towing
    lost the phone number and e-mail in my old confuser.............
    Post by dix Wed Dec 30, 2009 3:39 pm
    HERE IS THE INFO ON THE REPLACEMENT BUSHING THAT WILL WORK ON THE A100 TRANNY http://www.prothane.com/productguide.php THEN APPLICATIONS THEN APPLICATIONS MAKE & MODEL THEN GO TO THE 2ND PAGE NEAR THE BOTTOM YOU ARE LOOKING FOR 73-87 GM /CHEVY FULL SIZE TRUCK SPRING & SHACKLE BUSHING REAR/ 4 WD PAGE DOWN TO PICKUP 4WD 1 TON WITH 3950 LBS RATING YOU NEED 73-87 FRAME SHACKLE BUSHING KIT WITH 1 3/4 OD # 7-804 ( MAKE SURE YOU ORDER 1 3/4 OD YOU WILL HAVE TO CUT THE BUSHING & THE STEEL SLEEVE DOWN . BUT THAT IS EASY YOU WILL GET 4 BUSHINGS & 2 SLEVES FOR ABOUT $ 16.00 THEN YOU CAN SELL THE OTHERS TO MEMBERS IN NEED. HOPFULLY FOR COST & SHIPPING . THESE ARE URATHANE BUSHINGS .. MUCH BETTER THAN RUBBER.. YOU MAY BE ABLE TO FIND THEM AT A AUTO STORE SINCE YOU NOW HAVE THE APPLICATION....ALL THIS LEG WORK WAS DONE BY STEVE SCOTT AKA SCOTTIE IF YOU KNOW HIM THEN YOU THEY WILL WORK DIX...
    Post by dix Wed Dec 30, 2009 5:26 pm
    OK I JUST INSTALLED MINE 1ST AFTER THE OLD MOUNT IS OUT I USED A WIRE WHEEL ON A DRILL TO CLEAN OUT THE HOLE. ON THE LARGER SIDE OF THE BUSHING GRIND THAT PART ON A TAPER SMALLER THEN THE BUSHING OIL IT UP USE A ALLTHREAD ABOUT 5-6IN LONG A NUT& WASHER ON 1 END THEN A WASHER BIGGER THAN THE 1 3/4 HOLE WITH SPACERS / OLD SOCKET OR PIPE . THEN A SMALLER WASHER & NUT LINE IT ALL UP & TIGHTEN THE ALLTHREAD .IT WILL PULL IT RIGHT IN THEN CUT OFF THE END YOU TAPERED . IT TOOK ABOUT 1 HOUR.
    Trans Mount Empty trans mount
    Post by Guest Mon Feb 15, 2010 7:07 pm
    Hi,
    I am switching a 3 speed stick for a 727 auto. The trans mounts are different.
    Does anyone have the rear upper mount for the 727. The part number is
    2507889. New or used will be just fine. Let me know, thank!!!!!!!!!!!!!
    Craig (a-100 sl6)
    Number of posts : 1605
    Post by itruns Mon Feb 15, 2010 7:26 pm
    George was snowed in last week and was doin' a lot of digging.
    ustow@ptd.net
    Post by dix Wed Feb 17, 2010 1:16 pm
    I used the bushing from prothane and it worked great. they cost $18.00 you get 4 sell the other 3 to the guys on here to share the cost...
    Post by Guest Wed Feb 17, 2010 5:14 pm
    Are you talking about auto trades or the manual trans? The auto trans has a metal
    portion with the rubber mount seperate. The manual trans has the donut shape
    portion that is available thru prothane.
    Craig (a-100 sl6)
    Post by Guest Wed Feb 17, 2010 5:18 pm
    Dix,
    Additional info, the part number for the auto trans
    is 2507889. Any help would be appreciated.
    Thanks Craig
    a=100 sl6
    Post by Guest Tue Mar 09, 2010 9:44 am
    George gets his mounts from Springs n Things. www.espo.com or you contact Brian Bowie at a100vans@comcast.net for more info.
    Post by donivan65 Tue Mar 09, 2010 3:59 pm
    In my ChevyLand, These urethane bushings are kind of hard,,,,,,they transfer and amplify the noise and vibrations from the transmission to the floor and into the van,,,,,,,,I surely won't use them unless I can't find some rubber ones,,,,,,,,,
    Trans Mount 2nd_tr10
    gravesj
    Number of posts : 34
    Registration date : 2009-02-11
    Post by gravesj Thu Apr 01, 2010 10:27 am
    Any pics of the new bushings installed???
      Current date/time is Fri Apr 26, 2024 10:41 am
