    230/250 headers
    Number of posts : 801
    230/250 headers Empty 230/250 headers
    Post by panelmanrd Mon Dec 21, 2009 8:01 pm
    does anybody know what year and model headers will fit a 67 g10 with a 250?
    any brand or type of header? A friend of mine found a set for a 67/72 chevy truck 250
    anybody know if they will fit?
    230/250 headers Empty Re: 230/250 headers
    Post by Guest Mon Dec 21, 2009 10:53 pm
    I am running these headers on my 194. The PO installed them so im not exactally sure how difficult it was. But I can tell you this, unless you are running a throttle cable you will have to modify your throttle linkage because the main rod will run right into those headers. All that was done to mine is theres a U shaped extension thats abought seven inches long that goes around the headers. There has been some talk about the truck headers hanging too low for our vans but I have never had any clearance issues. I think its cool that you can see the headers under the van and they make the little 194 sound good. hope this helps.
    Number of posts : 7900
    Post by DanTheVanMan Tue Dec 22, 2009 6:33 am
    230/250 headers Qr_cod10
    oo3
    Number of posts : 290
    Post by oo3 Tue Dec 22, 2009 12:10 pm
    there are some guys running these - http://www.stoveboltengineco.com/acartpro/product.asp?productid=171 - thats the way i would go if i still had a chevy - oo3
    Post by Guest Tue Dec 22, 2009 7:29 pm
    i have a set of clifford long tubes, they were on a buds van. have hedders, 4bbl water heated intake and valve cover. im going to use the valve cover but sell the intake and hedders so i can buy the stove bolt manifolds or send my exh manifold off to be split. i would rather have a split manifold so i have the intake heated.
    Number of posts : 1135
    Post by benwah Sat Dec 26, 2009 8:14 pm
    bowtie56jw wrote:i have a set of clifford long tubes, they were on a buds van. have hedders, 4bbl water heated intake and valve cover. im going to use the valve cover but sell the intake and hedders so i can buy the stove bolt manifolds or send my exh manifold off to be split. i would rather have a split manifold so i have the intake heated.
    I have a 235 62 K-20. (I'ts low milage with 40 psi oil pressure!) Just want to get more nut out of the six, had 17's stock with 4:56 gears will have the same gears but 16.5 36" tires. Will they fit my truck?
    Post by Guest Sun Dec 27, 2009 6:40 pm
    sorry man wont fit 235 but there is a split manifold on ebay now.
    Post by Guest Fri Feb 05, 2010 10:07 am
    I just pulled out my 250 or 230 6, (I have to find out which it was), and it has a beautiful chrome head. Its for sale. what size do you need? If your interested, I'll have to finally go get the engine block numbers and figure this out.
    Heavy
      Current date/time is Sun Apr 28, 2024 3:30 am
