+4
mcfly
8 posters
    Undercoating ?
    mcfly
    mcfly
    Number of posts : 626
    Undercoating ? Empty Undercoating ?
    Post by mcfly Sun Dec 13, 2009 5:25 am
    Ok, guys getting real close to putting the Econoline on the road.
    Since I live on the East Coast I have to do some kind of undercoating before I drive it on these roads.
    What do you suggest ?
    Por 15 ?
    The underside of this van has no rust and I would like to keep it that way.
    And yes I plan on driving this one year round.
    mike
    Undercoating ? Empty Re: Undercoating ?
    Post by G-Man Sun Dec 13, 2009 5:41 am
    Any product will help being you said there nothing there now. The key is to get whatever you use every where there are tight corners and hard to reach place where that salt can get trapped. I have heard good things about Por's , but I think its applied with a brush??? You need a product that can be sprayed to get in those tight areas
    mcfly
    mcfly
    Post by mcfly Sun Dec 13, 2009 7:11 am
    Can you spray por ? I was thinking about using a cheap or old gun.
    mike
    Post by G-Man Sun Dec 13, 2009 7:16 am
    Not sure if you can spray por's??? Maybe someone here knows??
    Number of posts : 7900
    Post by DanTheVanMan Sun Dec 13, 2009 7:45 am
    Mcfly,
    You can spray POR but you need a very old gun or better yet a undercoating sprayer. If you use an old gun, you need to drill it out to 1/16" otherwise it will clog up. Also it has to be thinned by about 50%. Like applying any undercoating it is messy!!! But yes you can spray POR......
    Undercoating ? Qr_cod10
    Number of posts : 2067
    Post by sasktrini Sun Dec 13, 2009 11:08 am
    You can (should) buy POR thinner to spray POR 15
    Post by G-Man Sun Dec 13, 2009 11:43 am
    If you not spraying it for show, put it on thick. Most important thing is to clean the undercarrage well before applying.
    Post by donivan65 Sun Dec 13, 2009 11:44 am
    About 5 years ago, I used this ZeroRust under my van and inside the doors. I cut holes on the insides of my rocker panels and sprayed and rolled it in there. It still looks good,,,,,has not chipped or peeled. Looks like they use it on boats,,,,,,
    http://zero-rust.com/?referrer=google&gclid=CNPV_7yV1J4CFQMUawodfjp4CA
    Undercoating ? Pc030910
    Undercoating ? Th_TransPaint
    kgdb
    kgdb
    Number of posts : 266
    Registration date : 2009-12-03
    Post by kgdb Sun Dec 13, 2009 1:30 pm
    you can by Por 15 kits that include the proper reducer. It will spray well through a hvlp spray gun, I have done it many times.
    kgdb
    mcfly
    mcfly
    Post by mcfly Sun Dec 13, 2009 2:23 pm
    Thanks guys
    mike
    wacko
    wacko
    Number of posts : 423
    Post by wacko Sun Dec 13, 2009 6:45 pm
    I beleive POR15 is designed to be apllied to rusty surfaces. I have read on other forums of people using it on new frames and have a problem with it peeling. When applied to surface rust I think there is a chemical reaction which causes the bond.
    Since you mentioned your van bottom is currently rust free you may be better of using something else.
    mcfly
    mcfly
    Post by mcfly Sun Dec 13, 2009 8:20 pm
    Your not so wacko after all. That is a very good point. I have to look into that.
    mike
    Number of posts : 466
    Post by Sy Hollinshead Sun Dec 13, 2009 11:24 pm
    You can buy some other stuff to treat clean metal before you use POR15. I used POR15 straight onto bare metal and it just peeled off way too easily....!!! Not sure what you would use to paint it onto existing paint though....
    Oh, and it sprays very easily, but just be careful, as it doesn't dry as quickly as normal car paints, so you end up with a thin mist of the stuff on everything in the garage, including the floor, walls and ceiling.......!!!!
      Current date/time is Fri Apr 26, 2024 8:21 am
