I knew there had to be more to you than just a set of brackets, Michel. You sure got a good handle on things. You're setting a good example for your son to follow. And the Old Lady thing sure is hard to get right.....
64 rear axle
- Post n°26
Re: 64 rear axle
- Post n°27
Slots in rear gasket...
I suspect those slots have a dual purpose. One, to keep the shaft tubes from loading up with oil AND two, to keep bits and pieces like broken teeth from getting lodged in the shaft. My ring teeth are broken yet I am not able to find any pieces. Will be interesting to see if they ended up in the axle tube or the prior owner just cleaned them out and kept running with broken teeth. Glad I haven't had a rear wheel lookup.
And related to stiff Posi, has any body tried a super lubricrant like synthetic gear lube or really thin synthetic to loosen up the posi? Of course, not adding any friction modifier might help too. Just curious because I would like to be able to take my flattie off road for camping and such and would love to have Posi.
Happy motoring, Mark
