    New to me, 1969 108
    New to me, 1969 108 Empty New to me, 1969 108
    Post by Guest Mon Sep 28, 2009 7:34 am
    Purchased yesterday, seller had this, a Corvair Van, and a '77 Dodge. Couldn't look at the others after seeing this one.
    The bad: Outside rockers and driver's floor are all ate up. Dents, dings, scratches. Running on 3 cylinders.
    The good: Otherwise awfully solid, spare front and side doors, axles, etc., and a good spare 250.
    I'm having the seller (owns a hot rod shop) refresh the motor and do the swap, and refresh the brakes. I just don't have time/space/lift to do that right now, I'd like to have this be a drive-it-around while I redo it.
    I'm coming from the land of International Harvester trucks, travelalls, and scouts, so I liked the simplicity of this one. I can rewire it on a Saturday if I need to. :-)
    New to me, 1969 108 3k93pf10
    I was maybe waffling and then I saw this inside the cargo door:
    New to me, 1969 108 Ramada10
    Number for the Ramada Inn in St. Petersburg. That's what I call provenance. :-)
    I look forward to sharing more as the project continues.
    Best,
    J
    Number of posts : 2626
    New to me, 1969 108 Empty Re: New to me, 1969 108
    Post by savage Mon Sep 28, 2009 7:49 am
    You can get repair panels for most of the lower rust. They use to make alot of IH trucks & Scouts here in Ft Wayne
    Post by Guest Mon Sep 28, 2009 7:51 am
    Savage, I forgot to mention I get an original driver's side complete rocker in the deal.
    But then I did see the panels on eBay, shipping is big $! I may see if I can get them to work their way South a friend at a time. I'd been considering molding up some fiberglass ones but if there are panels ready-made, that's easy enough.
    And yes, a whole lot of Binders came out of Ft Wayne!
    Number of posts : 1651
    Post by Scott Mon Sep 28, 2009 8:05 am
    While refreshing the brakes you might make sure he runs all new lines, they are cheap and should be real easy to do while he is refreshing the brakes.
    You gotta figure that the lines are 40 years old, and corrode from the inside out.
    Looks like a fun project, looking forward to seeing it come along.
    Post by Guest Mon Sep 28, 2009 8:08 am
    Scott,
    You're right on the money. We figured master, lines, and at the very least a check on the cylinders. Hard parts appear to be in good shape.
    I'm willing to do further work over time, I just need to have something that can be safely driven around town while I work on the rest of it. I don't have 5 acres here like I did back in Carolina when I was collecting the Internationals. You can lose a lot of trucks back in the woods.
    Post by G-Man Mon Sep 28, 2009 1:40 pm
    Welcome to the site, be sure to check the links pages for small parts needs
    http://www.vintage-vans.com/chevy_parts_dept.html
    Number of posts : 331
    Registration date : 2009-02-24
    Post by crazee Tue Sep 29, 2009 4:05 pm
    savage wrote:........They use to make alot of IH trucks & Scouts here in Ft Wayne
    And I always thought they made em in Springfield ,Ohio. hmmmmmmmmmmm.........interesting bit of trivia.
    My old 67 Scout 80 with the 4 banger/3 speed was the best 4x4 I ever owned. Been hunting all year for another one actually ( 4 banger & not rotted).
    NICE find on the VAN too! And DITTO on the WELCOME!
    Very Happy
    Post by Guest Tue Sep 29, 2009 4:46 pm
    crazee,
    Ft Wayne and Springfield are the twin cities of IH light line production.
    I had a 4x4 4cyl 4 spd '71 and miss it terribly. Can't find solid scouts down here in FL, when I was in NC you couldn't turn down a country road without seeing one in the weeds.
    Thanks to all for the welcomes. Engine seals and freeze plug work today and general clean-up. We're going to hold off on the brakes right now, they are working, and I can do that in time. Likely I'll put in all new from master to slaves.
    crazee here's my old scout for you!
    J
    New to me, 1969 108 800woo10
    Post by Guest Mon Oct 05, 2009 2:51 pm
    The Van has arrived!
    Have started it up two days in a row, pretty easily considering it's just a straight pipe exhaust. A little backpressure and it should be running like a sewing machine. Still getting used to the three on the tree -- first one despite owning 20+ old Internationals.
    1st step will be cleaning her out, then the bodywork. Have done my share of sanding, some fiberglass/carbon fiber work, but I'm not a pro body guy. We'll see how it works out. Glad to have the complete driver's side rocker from a donor van. Currently planning on Smoke Gray rustoleum to cover the van, going for an industrial stealth look on the outside. Though I do have another gallon of safety yellow, so maybe we'll jazz it up.
    After that, the exhaust and electrics, just the basics. Then the customizing. :-)
    Enjoy the pics!
    J
    New to me, 1969 108 Vanarr10
    New to me, 1969 108 Vanarr11
    New to me, 1969 108 Vanarr12
    New to me, 1969 108 Vanarr13
    Post by Guest Mon Oct 05, 2009 2:57 pm
    New to me, 1969 108 Vanarr14
    New to me, 1969 108 Vanarr15
    New to me, 1969 108 Vanarr16
    New to me, 1969 108 Vanarr17
    Post by Guest Mon Oct 05, 2009 4:29 pm
    that is a sexy motor
    Post by Guest Mon Oct 05, 2009 5:48 pm
    had a 1959 international 4x4 miss it to the things we should have hung on to New to me, 1969 108 Scan0010
    Post by Guest Mon Oct 05, 2009 5:49 pm
    That's a BRILLIANT truck. Jealous of your time with it.
    Post by Scott Mon Oct 05, 2009 9:27 pm
    That's a great picture..
    I don't know who your with, but its pretty cool.
    Post by crazee Tue Oct 06, 2009 4:40 pm
    Yep......very clean looking engine......and a fun project. Another one gets to LIVE!!!! Smile
    Watch out speed shifting that Chevy 3 on the tree until you see how much slop is in it.
    Noting more fun than climbing under her in a busy intersection and removing the tranny side plate to un-jam her after you get the shifter forks jammed between gears.
    Been there/ done that - --> too many times ............"...........
    Razz
    Post by Guest Wed Oct 07, 2009 10:46 am
    Just running around the parking lot right now, but, yep, taking it slow with that shifter.
    Trailer load of the last parts scheduled to arrive on Tuesday:
    New to me, 1969 108 P1011910
    The rear axle's under there too.
    J
      Current date/time is Sun May 19, 2024 10:36 pm
