    HI,,,,,,,energy
    HI,,,,,,,energy Empty HI,,,,,,,energy
    Post by donivan65 Fri Jul 04, 2008 5:01 pm
    This would be the 3 types of GM distributors,,,
    The points and Condenser one
    The 1st Edition HEI with the external coil,,,1976-78
    and the 2nd Edition HEI with the coil built into the cap,,,,1979-86?
    And a video of an HEI test,,,,(take #2)
    HI,,,,,,,energy 3_dist11
    HI,,,,,,,energy Th_PHOT0001
    Number of posts : 1046
    HI,,,,,,,energy Empty Re: HI,,,,,,,energy
    Post by VANagain Sat Jul 05, 2008 2:18 pm
    What a great, simple demonstration! It really shows that it's not as complicated as it seems. The distributor only does one thing: provide a spark at the right time as its shaft is turned.
    Don, we need to get you your own TV show. Classic Cars Made Easy!
    Post by donivan65 Sat Jul 05, 2008 3:17 pm
    Thats all there is to it,,,,pull your distributor cap off, look where the rotor is pointing, pull it out and put the HEI in with the rotor pointing in the same direction and add 12 volts to the terminal marked battery,,,,,
    HI,,,,,,,energy Hei_ho10
    Post by Vanish Sat Jul 05, 2008 5:16 pm
    Don I got the Dist Hold down here if ya need it !!!!!!!!!
      Current date/time is Mon May 13, 2024 5:05 am
