+8
VanninBlaino
badnova
LowSchooL
Artesian
12 posters
    Lowering a 67
    Lowering a 67 Empty Lowering a 67
    Post by Guest Wed Aug 05, 2009 6:56 am
    Hi all, I just bought a 67 chevy van, I am working on getting it roadworthy, and dropping it. So this here is my inspiration for the van.
    Lowering a 67 Chevy
    I tried to PM the guy who owns it on cardomain, but no luck. From what I can gather it's a static drop without bags, or a dropped axle. At least now I know it can be done.
    Here is a pic of the stock suspension
    Lowering a 67 173
    One of the front spring perches was smashed, So I had to cut it off to straighten it. I went ahead and cut off the other one and modified both of them to move straight up 2 inches. The van is setting kind of crooked now, but it's got 4 different sized tires on it, so I'm not sure if the springs are bent or what. I am going to flip the axle this weekend and see where that gets me. I might need to narrow it too. Plus it's on 15's now and I'm going to 14's. The plan is to get the front as low as I can with it being comfortable to drive, then match the rear, So I might be driving it around with a stupid rake for a bit! lol. Am I on the right track, or is there other tricks for doing this?
    Thanks
    Lowering a 67 Empty Re: Lowering a 67
    Post by Guest Wed Aug 05, 2009 10:27 am
    I cut all 4 front spring perches on my '69 GMC and it lowered the front of the van about 2" or slightly less. i ended up cutting open the perches and allowing them to slide further up on the frame. My spring eye holes are close to the frame. I kept the stock axle and run 14" cragars on front. Haven't lowered the back. Good luck with your project!
    Post by Guest Wed Aug 05, 2009 3:16 pm
    Do you have any pics of it?
    Post by Guest Thu Aug 06, 2009 5:43 pm
    Lowering a 67 Van
    Nice job KC. Anyone else dropped their van? Dropped axles? flipped axles? anything? You guys aren't a bunch of stock purists are you? hahaha!
    Post by Guest Fri Aug 07, 2009 1:19 pm
    Fu_Manchu, Thanks for compliment! Did the pictures of my cut spring perches help you at all? If you look at the picture of the rear spring shackle, you will notice my lower bushing is where the top bushing once was. I know you want your van down in the weeds. I'm not a suspension expert, but watch out for your drag link while lowering your van. I knew a guy who dropped a '66 Chevy really low and he took it on the freeway and it jumped over a lane from a dip in the road. Bump steer?? My goal was to get a little rake without raising the rearend.
    Artesian
    Number of posts : 5
    Registration date : 2009-08-09
    Lowering a 67 Empty New Guy with lowered van
    Post by Artesian Sun Aug 09, 2009 11:20 am
    I'm new here on this site. Here is a pic of my lowered van that has been off the road for way too long. I like 'em low.
    Lowering a 67 Picture014
    Post by Guest Sun Aug 09, 2009 2:14 pm
    Artesian - very cool. I remember seeing a picture of it some years ago. Is this the same van that has an S-10 or Astrovan front suspension? Did you move your rear axle on top of the leafs?
    Artesian
    Number of posts : 5
    Post by Artesian Sun Aug 09, 2009 2:57 pm
    Fu - KCs approach might be the easiest. Or you can get the axle dropped up to 4 inches. It looks like dropping a supplied axle costs $200
    http://www.roadsters.com/axles/
    There is another place in Oakland Ca, that drops axles called Mor-Drop. Do both and get up to 6" drop (Oh Yeah).
    Thanks KC, my van is the same one with the astro front, corvette rear, and mid engine 454-4L80. I have been distracted by other projects and life, but hope to get it going for next season.
    I really like lowered vans and there should be a way to lower the front using the original spring mounts and the straight axle by replacing the springs with a 6 link. I had a setup on the back of an s-10 like this:
    Lowering a 67 4CBO-S11_AT
    The same idea could work on the front of a van if you wanted it bagged.
    Number of posts : 2067
    Post by sasktrini Mon Aug 10, 2009 7:49 am
    That's cool... I wondered about using a rear setup in the front like this, probably with a panhard bar rather than the centre links...
    Post by Guest Fri Aug 21, 2009 11:00 pm
    Lowering a 67 Cleanwires008
    Lowering a 67 Cleanwires011
    Got the front end in the weeds. Still playing with it, probably a 4 link is going in the back.
    Number of posts : 2626
    Post by savage Sat Aug 22, 2009 8:22 am
    Looking better already, So what all you do to the front of your 67???
    [img]Lowering a 67 File0110[/img]
    I droped my NY 65 with fliping the springs ,front needed to be a little lower,and it didn't drive to well(in & out of my driveway),but did look cool(well if I finish the primer paint job Laughing
    Lowering a 67 Empty Update
    Post by Guest Sat Aug 29, 2009 6:14 pm
    Lowering a 67 IMG_4296
    Lowering a 67 IMG_4298
    Lowering a 67 IMG_4297
    Lowering a 67 IMG_4295
    Still gotta bring the front end down some more, and figure out tires, My lantera rollers are way to small. New doors, body and paint next.
    Artesian
    Number of posts : 5
    Post by Artesian Tue Sep 01, 2009 10:45 pm
    THAT'S what I like!!!!!
    Post by Guest Wed Sep 02, 2009 9:08 am
    Thanks Artesian, Your van is amazing BTW! I'm still learning about these vans, what are the mirrors on yours? I know they are factory, but what years etc. I need a set.
    Post by G-Man Wed Sep 02, 2009 9:32 am
    Fu_Manchu, those are stock and they were the cheapo mirrors of there time, but they are also the mirrors everyone wants now. Kind of hard to find, but not impossible
    Post by Guest Wed Sep 02, 2009 9:39 am
    G-Man wrote:Fu_Manchu, those are stock and they were the cheapo mirrors of there time, but they are also the mirrors everyone wants now. Kind of hard to find, but not impossible
    I love "hard to find", the thrill of the hunt! I got some of the parts for my Buick from Finland. hahaha! Very Happy
    Where they available 64-69?
    Post by G-Man Wed Sep 02, 2009 10:06 am
    I'm pretty sure that mirror for the most part was used on 1st gens 64-66, but not 100% on that
    Post by Guest Thu Sep 03, 2009 10:35 pm
    I didn't know where to post this, but I need some help. I got my seats back from the upholstery shop,
    Lowering a 67 002-4
    They werent bolted all the way in when I pulled them, and I think some of the brackets were missing, can you guys show me some pics of seats bolted in so I can see what I'm missing?
    OH, White pearl vinyl, what do you think?
    Post by Guest Sun Sep 27, 2009 7:33 pm
    Getting closer to paint!
    Lowering a 67 P9270673
    Lowering a 67 P9270670
    Post by G-Man Sun Sep 27, 2009 7:35 pm
    What color are you going with????
    Post by Guest Sun Sep 27, 2009 7:39 pm
    Hot rod flatz...
    old gold metallic,
    carnival red pearl,
    copper pearl,
    plus I got a big jar of sunshine pearl powder that I might try to add to get some inbetween shades.
    Plus pearl white accents but gloss on the interior.
    Think late sixties...only semi-gloss
    http://www.tcpglobal.com/kustomshop/ksflatz.aspx
    LowSchooL
    LowSchooL
    Number of posts : 9
    Registration date : 2010-11-10
    Post by LowSchooL Wed Nov 10, 2010 7:01 pm
    I Posted pics on the old forums of some of the work i did to lower the Van, i will try to link some pics i have posted up so whoever is interested can view,
    First prototype bracket i built
    http://dkm.smugmug.com/Cars/1969-Chevy-Van/Vanbracket3/96031529_ujuiQ-S.jpg
    Lowering a 67 96031529_ujuiQ-S
    picture of it installed
    Lowering a 67 106471183_BNaaJ-M
    another view angle
    Lowering a 67 106471272_Xd7iq-M
    the rear obviously easy old school leaf flip
    Lowering a 67 146954131_ayrmF-M
    finished stance
    Lowering a 67 146954797_sFDrv-M
    Lowering a 67 146952889_7gYk7-M
    Lowering a 67 146954642_jZKMr-M
    Post by EconoCarl Wed Nov 10, 2010 8:00 pm
    Good lookin' van LowSchooL!
    Post by Guest Fri Nov 12, 2010 11:05 pm
    does the drag link need to be modified mounting the axle above the springs like that in the front end? how does it handle, any bump steer?
    badnova
    Number of posts : 24
    Registration date : 2010-08-16
    Post by badnova Fri Nov 26, 2010 6:52 am
    hey lowschool just curious what size rims are those (height wise)
      Current date/time is Fri May 10, 2024 7:39 pm
