not new but new to me lol
wylee- Number of posts : 917
hi gang, starting to do some work on my front end. 69 a108. she wanders down the road quite bit. got the front up on jack stands.ther is a very little play wen i wiggle the tire left to rite. i see the drag link and tie rod ends move. i can roll the drag link back and forth a little. also noticed the front swaybar bushings are shot. i try to move the wheel up and down, king pins, no movement.what can i do about the drag link i know thats hard to get thing. i would love any advice. thank you wylee
Re: not new but new to me lol
savage, dix, gmytych and kiwimopar like this post
How is the king pin repair coming along?
the rite side is done and installed. hafta put the new swaybar ends on yet.waiting for the new schocks to come in, new tierod ends are slao on.
gmytych likes this post
gary h- Number of posts : 474
Where did you find the Sway bar Bushings ? Part numbers ? Thanks
gary h likes this post
I bought some n.o.s. Bushings a few years back, and sold the extras here on the site, I don’t remember the actual part numbers.
im so sorry i dont have the part numbers, or ware i got them. i threw out the boxes they came in, i have many parts for all differnt cars i dont keep track. i should be more organized. i just got them last week. there still out there.goggle or serchgary h wrote:Where did you find the Sway bar Bushings ? Part numbers ? Thanks
From a thread here in 2010 ,I found "K 8662" and "K 8663" link kits. Which is Correct ?
gary h and sweetvan like this post
Thanks for the Pic. How long are the Links ?
kiwimopar- Number of posts : 744
Good work on the King Pin replacement.
Never go for the nylon bush option....they do not last very long at all. I fell into that trap first time around. Changed out after less than 1,000 miles to the bronze bushes.....much better now.
Also for the sway bar links, I used the ones from the Ford as recommended by a member here quite a few years ago.
Moog Sway Bar End Links K8662 - no longer available at Summit Racing.
gmytych, gary h and sweetvan like this post
gmytych, kiwimopar and gary h like this post
Rockauto has the End links.
kiwimopar and sweetvan like this post
On the Lower mounting of the End link ,Is the bolt part of the lower shock mount or is it separate ? Thanks in Advance
kiwimopar likes this post
one long bolt for both
gary h wrote:On the Lower mounting of the End link ,Is the bolt part of the lower shock mount or is it separate ? Thanks in Advance
Agreed with above....you need a longer bolt for both the shock and the end-link.
I also found that with my disc-brake upgrade, the sway bar was interfering with the swing of the caliper. So now I have removed the sway bar while I source a custom-made unit and alter the end link fixing points.
Just something to be aware of.
Mine were took just a couple taps with a mallet and they popped off. Got lucky for sure.
wylee likes this post
- Post n°19
funny the kingpins wernt all that bat bad lol
