    1967 A108 Sportsman
    tread
    tread
    Number of posts : 7
    Registration date : 2022-07-29
    1967 A108 Sportsman Empty 1967 A108 Sportsman
    Post by tread Sat Jul 30, 2022 4:39 pm
    Doing a `67 A108 into a camper.  No solid long term goals, just need to make it run and drive.  318 'runs' but needs some love.  This is my second dodge, first a '54 pilothouse job rated with 218, owned since '74.  Otherwise been fooling around with vw busses for 20 some years.
    Van has been sitting for quite some time.  Tuned it up and static timed it and it ran, but definitely needs a carb.  Has the carter thermoquad, which as I understand is way too much carb.
    Staying with a 4 barrel, what would fit this manifold and be more appropriate (maybe 600 cfm)?.  Or is there a better manifold/carburetor setup?  Van is 3 speed auto.
    Thanks!
    1967 A108 Sportsman 67701714
    kermit likes this post
    Number of posts : 8731
    1967 A108 Sportsman Empty Re: 1967 A108 Sportsman
    Post by dix Sun Jul 31, 2022 3:38 am
    a 600cfm is too much carb for a driver. I don't know what manifold you are running
    but id run a 500-cfm carb. dodge never made a 318 with a 4 barrel
    gmytych likes this post
    tread
    tread
    Number of posts : 7
    Post by tread Sun Jul 31, 2022 7:05 am
    Ran into that at the parts store.  The engine is obviously a transplant, I bought the van from a friend of mine with a `73 sportsman, he said there was something different about this engine
    Dude I talk to up at the parts store knows his mopars so has been giving me advice.  He recommended the 600 cfm vs the 850 cfm thermoquad.
    1967 A108 Sportsman Img_64131967 A108 Sportsman Img_6810
    Trying to clean up the block to get the casting numbers, see exactly what's in there.  I was told it's a 318 and the parts house has been running a '68 charger as a cross reference for parts.
    tread
    tread
    Number of posts : 7
    Post by tread Sun Jul 31, 2022 7:37 am
    The carb, carter thermoquad.
    1967 A108 Sportsman Img_6710
    1967 A108 Sportsman Img_6711
    Had some super ghetto linkage with hose clamps and such.
    tread
    tread
    Number of posts : 7
    Post by tread Sun Jul 31, 2022 11:21 am
    Block number after some purple power and pressure wash.
    1967 A108 Sportsman Img_6811
    Post by dix Sun Jul 31, 2022 2:51 pm
    the block #s should be down by the freeze plugs
    gmytych and OutofSight like this post
    tread
    tread
    Number of posts : 7
    Post by tread Tue Aug 02, 2022 10:02 am
    1967 A108 Sportsman Img_6813
    1967 A108 Sportsman Img_6814
    Passenger side shows D N (or W?) then date 7.24.67
    So a 1967 318(?).  Any idea what this manifold may be from?  I am debating pulling the lump to clean it up real good but would much rather put a carb and possibly a different manifold on there and let it run.  Parts man suggested pull a part for an intake/carb, but I'm  not likely to find anything that old at our pull a part.  I am not averse to buying something used or aftermarket,  just don't know what I need.
    Suggestions?
    Thanks!
    tread
    tread
    Number of posts : 7
    Post by tread Sun Aug 07, 2022 11:55 am
    Summit racing has a number of carter 4 bbl 318 remans, most are listed for '80s sedans.  Buddy at the parts place said find one for a vehicle of similar size/weight. A 108 is a massive heavy machine. Talked to them this afternoon, they are going to contact their carb remanufacturer and see what they can do.
    Post by dix Sun Aug 07, 2022 5:27 pm
    the 108 is only 18" longer. maybe 200lb.more. a little more sheet metal and a longer drive shaft.i
    DanInWNY
    DanInWNY
    Number of posts : 9
    Registration date : 2020-07-23
    Post by DanInWNY Tue Aug 16, 2022 2:19 pm
    dix wrote:a 600cfm is too much carb for a driver.
    Maybe, but it's just another 2bbl if you disable the secondaries.
    I've got a '65 Chevy G10 that came with an Offy aluminium intake, and I picked up a 600 cfm Holley for it. It should work out fine with the 292 I've got for it.
    chrlsful
    chrlsful
    Number of posts : 187
    Post by chrlsful Wed Aug 17, 2022 5:30 am
    I use Mike's Carbs to ID 'what I got' & "what I need". I run back'n forth over his site looking at the listings on his charts and noting down the info for cross overs. You MUST know how to read the carb U have 1st. Don't carters read off the #/ltrs hand stamped on the mounting flange? Not the cqstings. U must hold up by the face'n look at the side of the flange.
    Motor must B IDed correctly too.
    May even hafta know what cross overs U want (Y/M/M).
    demondog
    demondog
    Number of posts : 28
    Registration date : 2016-03-19
    Post by demondog Wed Aug 17, 2022 2:19 pm
    I think the intake is a transplant. It is blue in color relevant with 70's motors. The engine is orange red which was more in the 60's. Which I see in your pics of the block and valve covers.
    I think the intake has been swapped.
    tread
    tread
    Number of posts : 7
    Post by tread Mon Oct 24, 2022 4:58 pm
    Picked up a complete 360 'running when wrecked,' a busted trans, a rebuilt overdrive trans, rebuilt torque converter, (plus gas to and from), for less than a reman carb.
    360 needs new water pump (busted in wreck), and alternator (cracked housing). Current 318, I think ppo used pond water for coolant, probably scavenge and clean the water pump for the 360. Alternator comes later.1967 A108 Sportsman Img_7410
    1967 A108 Sportsman Img_7411
    1967 A108 Sportsman 68799210
    Post by dix Tue Oct 25, 2022 2:40 am
    look at the water pump on the 318 to the 360 the 318 pump may be shorter for the radiator clearance
    my guess you would want to run a newer rad, as well
      Current date/time is Tue May 07, 2024 9:07 am
