Looking for a 66 Handi-Van driver's door window regulator. I would guess that a 66 Chevy Sportvan would also work.
66 Driver's Window Regulator
66HV- Number of posts : 1
Registration date : 2022-06-24
Camaro Addict- Number of posts : 250
Registration date : 2012-07-08
Re: 66 Driver's Window Regulator
64-66 Chevy or gmc g10 should be the same
savage likes this post
AzDon- Number of posts : 742
I have one available from a 69.....Third gen used the clip-in-groove setup to fasten the crank on... not sure if you could use the set screw crank...
The regulator I've got has a good track roller and the lift spring is good.... Greased up and ready to go!
