    Steering column and front axle
    13-ball
    13-ball
    Number of posts : 87
    Registration date : 2020-07-23
    Steering column and front axle Empty Steering column and front axle
    Post by 13-ball Thu Feb 18, 2021 12:46 pm
    Stuff that needs a good home.  Was in a 1961 Econo pickup.  Open to offer but really don't want to ship this stuff.  In Moab Utah.
    Steering column and front axle 20210110
    Column, shifter, gear box, pitman arm, floor seal, turn signal stuff, wiring etc.  Don't know what the steering wheel is from - it's junk.
    Steering column and front axle 20210111
    Seems good except somebody messed up the shifter arms to make it shift an automatic trans.
    Steering column and front axle 20201211
    Front end complete hub to hub.  Brakes, spindles, sway bar, springs, steering links, shackles, etc.
    Rear end is a freebie.  Don't know what it's out of - has a VSS electronic sensor or something on it.
    Steering column and front axle 20201112
    Steering column and front axle 20200728
      Current date/time is Mon May 20, 2024 1:28 am
