    A100 / 108 Windshield Install
    A100 / 108 Windshield Install Empty A100 / 108 Windshield Install
    Post by Guest Tue Feb 09, 2021 2:19 pm
    Just want to make sure I got this right. I have a brand new gasket, truck new paint no rust around body edges:
    1. Install rubber gasket all the way around the body opening.
    2. clean glass for one side and lube with soapy water, also the rubber gasket on one side.
    3. Working from the outside of the truck, slide window in on the bottom, then up the pillar and across the top. Work the rubber with a plastic spudger
    4. When I get to the middle , push the glass as far as possible to the outside of the truck and carefully put the center rubber over the window.
    5. Take a break
    6. Do I use cord to install the second windshield piece?
    7. Lube the second side rubber and window, working from the outside of the truck, put glass in the bottom rubber and work around slowly skootching the glass in. If using cord, pull that from the bottom up on both side evenly,
    8 then across the top.
    Is that it?
    Thanks
    Number of posts : 8732
    A100 / 108 Windshield Install Empty Re: A100 / 108 Windshield Install
    Post by dix Tue Feb 09, 2021 3:16 pm
    I'M not aware of the cord , but yes you are correct, it's a bitch, took my wife and i over 2 hours .
    a helper does help a lot...
    Number of posts : 690
    Post by jrdunn96 Tue Feb 09, 2021 4:14 pm
    dix wrote:I'M not aware of   the cord , but yes you are correct, it's a bitch, took my wife and i over 2 hours .
    As long as you don't cuss 'em too much. Just kidding. I am careful about what I ask my wife to help with. Don't get me wrong, she's good help, I'm just a lousy boss. Mad
    Post by dix Tue Feb 09, 2021 6:17 pm
    i don't think lone wolf is the best idea....
    Number of posts : 405
    Post by Keith D Tue Feb 09, 2021 8:30 pm
    Definitely need two people.
    I had a glass installer come to my house and I helped him, definitely not an easy job.
    I was on the inside keeping the glass from falling in and he was on the outside of the van hitting the glass with his hands to get it in place. He did not use a cord, he used a metal hook to get the gasket around the glass.
    A good idea with new or good paint is to put down a couple of layers of painters tape directly under where the gasket is and then tape a thin towel under that. Better safe than sorry if the glass slips out or drops down.
    Number of posts : 1558
    Post by OutofSight Wed Feb 10, 2021 9:18 am
    That’s what I did as well. Worked out great.
    69
    69
    Number of posts : 434
    Post by 69 Wed Feb 10, 2021 11:07 am
    Did this myself and it worked ok. It's a pain to be careful all the time and have the whole glas in view, especially, when you try to work in the second glass into the middle channel.
    No cord used, not even for the insert. Take care to put it in the right side.
    And protecting the paint is as good an idea as soapy water. Be aware of possible scratches by your clothes (e.g. knobs of your jeans, zipper and such).
    A warm environment helps a lot to keep the rubber as elastic as possible.
      Current date/time is Sun May 19, 2024 10:10 am
