I am ready to reinstall the rubber strip on the bottom of the belly pan, since it has been emphasized that this rubber strip is necessary for cooling. My problem is that i don't recall exactly Where and How this was originally mounted. Does anyone have a good picture of the correct installation position for this particular part?
rubber strip on bottom pan
lboast- Number of posts : 112
Registration date : 2020-11-01
gmytych likes this post
Keith D- Number of posts : 405
Re: rubber strip on bottom pan
I hope this helps, one picture is of the underside clips used to hold the strip on, I think there were four clips.
gmytych, rekbender and lboast like this post
Thank you for the great photos. They are very helpful.
69- Number of posts : 434
Ahh, that#s what those holes are for. Running mine without that rubber strip (belly pan installed). No heat problems so far.
Thanks for the pics.
Dan Scully- Number of posts : 254
69 wrote:Ahh, that#s what those holes are for. Running mine without that rubber strip (belly pan installed). No heat problems so far.
I will have to look , mine does not have that also but no problem with over heating. I would assume that seals to the bottom of the radiator thank? Thanks
gary h- Number of posts : 474
Anyone Reproducing the seals ?
I'm not sure if they are being reproduced, but I did find the similar rubber strip on a newer chrysler vehicle in the wrecking yard, that was used as a lip under the hood. It was about 5 to 6 feet long, a d was in somewhat better shape than mine.
