    Rear Disc Brakes.
    gmytych
    Number of posts : 110
    Registration date : 2008-06-18
    Rear Disc Brakes. Empty Rear Disc Brakes.
    Post by gmytych Fri Jan 08, 2021 9:56 am
    Contemplating rear discs on the A. work has already started using Scotties conversion.
    I can always reassemble what I got.
    Has anybody else have rear discs and how do you like them.
    Is it worth the effort??
    Thanks
    Mytch
    dix likes this post
    Number of posts : 2086
    Rear Disc Brakes. Empty Re: Rear Disc Brakes.
    Post by Seth G Fri Jan 08, 2021 6:26 pm
    Speaking for myself from a Ford perspective and having planned and attempted to install rear discs, don't bother. It's a waste of time and money. Working out the parking brake is a nightmare, use 80's cadillac calipers? Other options. Regardless, in my case I found the spring lands on the rear axle interfered in such a way that I would have had to orient the calipers in a ridiculous way. I don't know what size the drums/pads are on your Dodge, but they're more than big enough on a ford Econoline 9" rear axle. My 93 Bronco is ABS and has rear drums and 35" wheels, it stops just fine as does my 64 Econoline. Discs in the front, drums in the rear.
    gmytych and Dan Scully like this post
    Post by Guest Sat Jan 09, 2021 4:42 am
    A's have 10 x 2-1/2 rear brakes. A cheap and easy upgrade is to swap on 11 x 2-1/2 rear brakes from a C-Body.
    Number of posts : 8729
    Post by dix Sat Jan 09, 2021 5:22 am
    i have not made the rear disc brake conversion the entire set up has been made functionable by Steve Scott .
    i believe mytch is asking after the conversion is complete how much difference does it make compared to the factory drum brakes.??
    i did make the front conversion and that makes a world of difference ,
    gmytych likes this post
    gmytych
    Post by gmytych Sat Jan 09, 2021 2:31 pm
    Dix is correct.
    I have Scotties disc conversion up front .
    The rears would be from 78 Jeep grand Cherokee.
    ALMOST bolt on conversion including parking brake.
    30$ in yard parts up till now.
    Mytch
    lear0
    lear0
    Number of posts : 86
    Registration date : 2017-04-28
    Post by lear0 Sat Jan 09, 2021 7:48 pm
    ford explorer,2000 or so year. 100.00 at junkyard. wil get you disc brakes
    ,traction lock with 3.73 gears. need to shorten the right side ,about 3". so you have a narrowed rearend all said and done.
    Post by dix Sun Jan 10, 2021 5:01 am
    back to what mytch ,
    would the rear disc brakes make much difference
    the money and parts and labor excluded .
    final product is it a game changer
    gmytych
    Post by gmytych Sun Jan 10, 2021 2:05 pm
    Decisions, Decisions , Decisions .....
    What I got is just fine. Just thinking about an upgrade.
    Could put the project on hold and think about it more.
    Still changing lefties to righties though. !!
    Post by dix Sun Jan 10, 2021 4:48 pm
    watch you dont bend the plate or drumbs the stud is attached to
      Current date/time is Wed May 01, 2024 6:50 pm
