    Russell's '66 GMC HandiVan
    Number of posts : 698
    Russell's '66 GMC HandiVan Empty Russell's '66 GMC HandiVan
    Post by Russell Fri Oct 16, 2020 8:20 am
    Some of you know I bought a Handi Van a couple of weeks ago. Let the fun begin!
    Russell's '66 GMC HandiVan Gmc_ha10
    Russell's '66 GMC HandiVan Gmc_ha11
    Russell's '66 GMC HandiVan 12018810
    Russell's '66 GMC HandiVan 12020010
    Russell's '66 GMC HandiVan Gmc_ha12
    savage, vanny, jrdunn96, Keith D, REIGNSoner and Bug like this post
    Russell's '66 GMC HandiVan Empty Re: Russell's '66 GMC HandiVan
    Post by Russell Fri Dec 04, 2020 6:57 am
    Just a update on some of the work being done on my GMC.I pulled the 6 cyl. out and installed a 350,The picture is before I cut the floor for the bigger doghouse.Russell's '66 GMC HandiVan Img_5210
    Russell's '66 GMC HandiVan Img_5211
    Russell's '66 GMC HandiVan Img_5212
    It isn't running yet but soon. Lot's to do
    savage likes this post
    Post by Russell Thu Dec 10, 2020 8:59 am
    Russell's '66 GMC HandiVan Img_5213
    Russell's '66 GMC HandiVan Img_5214
    I've been living in Chula Vista too long I think,
    savage and vanny like this post
    Post by Russell Mon Dec 14, 2020 9:11 am
    I used some edging trim for the shift rod bushing's.
    Russell's '66 GMC HandiVan Shift210
    Russell's '66 GMC HandiVan Shift110
    Russell's '66 GMC HandiVan Shift10
    Post by Russell Mon Dec 14, 2020 9:30 am
    Somebody hacked my radiator support, (P.O.)
    Adding a 2nd gen doghouse I noticed the bolt holes on the sides of the support are not going to attach it to the new doghouse. I thought they would work well for attaching a fan shroud. I have another radiator support from my other van, I cut some aluminum 30" x 6" and bent them over the round end of my vise to get the shape I wanted.
    Russell's '66 GMC HandiVan Fan1010
    Russell's '66 GMC HandiVan Fan610
    Russell's '66 GMC HandiVan Fan710
    I set them into the support and drilled holes where the existing holes are in the support.
    Then put them into the van.
    Russell's '66 GMC HandiVan Fan510
    Russell's '66 GMC HandiVan Fan410
    Russell's '66 GMC HandiVan Fan110
    Russell's '66 GMC HandiVan Fan210
    This seems to work well and was easy to make. Since 1st gen fan shrouds are rare to find I know some of you might be interested. I have an 18" fan and probably should have cut the strips a couple inches longer. I plan to add 2 small squares to cover the holes and support the sides. If I were to use the original support I will probably notch the top because of the angle of the top of the support. Since mine had already been cut off it went in easily.
    vanny likes this post
    Post by Russell Sun Jan 03, 2021 8:21 am
    Cutting out the hole for the later V8 style doghouse is not real difficult. I set the new one over the hole lining up the front where the old one sits around the brake handle etc. and marked it inside and outside on the floor. I used a saws all to cut the inside area out leaving the part from the radiator supports forward.
    The problem area is the rear section, the newer doghouse is shaped differently than the early one. I cut the rib's out so a new piece of flat metal could be placed over the floor section left. A little bit was cut out of the middle also to make the shape to match the new doghouse. A little welding, pounding and grinding and the hole is ready to put the new one in.
    The first picture is before cutting it out.
    Russell's '66 GMC HandiVan Img_5215
    Russell's '66 GMC HandiVan Img_5216
    Russell's '66 GMC HandiVan Patch210
    Russell's '66 GMC HandiVan Patch10
    Russell's '66 GMC HandiVan After10
    savage, vanny and Bug like this post
    Post by Russell Fri Feb 12, 2021 7:08 am
    I wanted to know how bad the tank looked inside.since I have 2 tanks and this one had a couple large dents in the bottom I decided to cut it open. Really crusty inside and seemed like it had some kind of coating, (rubbery?) The bottom section cleaned out easier than the top using just a scraper than some cleaners and scrubbing, the top part was alot harder substance and more rusty. I should be able to weld it back together and I'm thinking I might add a 2" strip between the two for a little more gas space.
    Russell's '66 GMC HandiVan Gas210
    Russell's '66 GMC HandiVan Gas110
    Russell's '66 GMC HandiVan Gas610
    Russell's '66 GMC HandiVan Gas710
    Russell's '66 GMC HandiVan Gas510
    Number of posts : 672
    Post by samsvan Fri Feb 12, 2021 12:56 pm
    It looks like an old grill.
    Post by Russell Sat Apr 24, 2021 9:43 am
    I haven't posted in a while some of the progress. New radiator, doghouse installed with latches to separate the back half for maintenance, made tunnel for more air into radiator.
    Russell's '66 GMC HandiVan Dg510
    Russell's '66 GMC HandiVan Dg210
    I will be able to remove the back half with the seats in place.
    wideload, savage, gmytych, vanny and Bug like this post
    Post by Russell Sun Aug 29, 2021 8:14 am
    Russell's '66 GMC HandiVan Img_5911
    It's been awhile since I've posted the progress.
    savage, gmytych, uncle ron, vanny and REIGNSoner like this post
    Post by vanny Tue Oct 12, 2021 4:41 pm
    Russell, I love your work . Are you keeping this one or selling it??? Let me know… please and thank you!
    Post by Russell Fri Oct 15, 2021 7:38 am
    Russell's '66 GMC HandiVan Img_6010
    Russell's '66 GMC HandiVan Img_6110
    It's getting really close to done. I don't know if I'm going to sell this one or the other one. After I drive it awhile I'll decide, I don't need 2 Vans.
    savage, vanny and jrdunn96 like this post
    Number of posts : 2626
    Post by savage Fri Oct 15, 2021 9:13 am
    I don't Need 6 VCV(& Astro)  Shocked  But got them(for now??)  Russell's '66 GMC HandiVan 1f60e
    Your van's looks Great Russell
    Post by vanny Fri Oct 15, 2021 4:08 pm
    Wow, now that's not an easy decision because they both look Fantastic!!!
    Number of posts : 1388
    Post by wideload Sun Oct 17, 2021 3:07 am
    Russell thanks to your FB post here's a link to a place that sells the fabric you used on the doghouse.
    https://www.parts-express.com/Speaker-Cabinet-Carpet-Covering-Charcoal-Yard-54-Wide-260-765?fbclid=IwAR1ax6rsf4oRtwb5Ms1h783V9MshssqN900Rj7HfpzBNp56XCWm_Fb4iCbI
    Do you remember about how much material it took?
    THANKS, wideload
    Post by Russell Sun Oct 17, 2021 9:08 am
    wideload wrote:Russell thanks to your FB post here's a link to a place that sells the fabric you used on the doghouse.
    THANKS, wideload
    I bought 4 yards but didn't use all of it. I just bought another 4 yards to do the inside window frames, the long one is just over 9' long. it is 4'6" wide so I can cut it in half and do all the frames.
    wideload and vanny like this post
    Post by Russell Fri Nov 12, 2021 10:59 am
    Russell's '66 GMC HandiVan Img_6210
    Russell's '66 GMC HandiVan Img_6211
    A couple of pictures of the cabinets I built to cover the wheelwells and corner with storage.
    savage, vanny and sweetvan like this post
    Post by vanny Fri Nov 12, 2021 4:14 pm
    Looks like that latch probably hooks so that it won't accidentally pop open during transit?
    I like the direction you're going with this...Great idea!
    Post by Russell Sat Nov 13, 2021 6:22 am
    Russell's '66 GMC HandiVan Gas_fl10
    Russell's '66 GMC HandiVan Gas_fl11
    Russell's '66 GMC HandiVan Sender10
    Russell's '66 GMC HandiVan Sender11
    I put a new sending unit in months ago and the gauge worked well, It was showing close to empty so I drove it to the station and put about 5 gallons in it, gauge stayed near empty. I didn't want to drop the tank again since it was near full. I tested the wiring and knew it had something to do with the sender. I cut a hole in the floor for access, pulled sender and tested it outside of the tank and it was working? after re-installing, still not working I pulled it back out and noticed small dent in the float, it had a small crack and was full of fuel. I drilled a hole on the crack to drain it and soldered it back together. Working great now. I was surprised the new float was not good. I added some flat stock under the floor for support and replaced the piece I cut out. Easy access if I ever have to work on it again. Just because a part is new doesn't mean it's good.
    savage, gmytych and vanny like this post
    Post by Russell Mon Dec 06, 2021 8:52 am
    Russell's '66 GMC HandiVan Floor210
    Russell's '66 GMC HandiVan Floor10
    I have some flooring I was thinking of putting in the Van but when I laid it out it just looked like too much with the wood side panels. I did cut some to try to level out the floor rib's. It is the perfect width set into the lower ribs, I will be putting padding and carpet over the floor area.
    My wife liked the way the floor looks with the rib's filled. If the floor were painted and the cuts were nicer on the wood it would be a nice look for a cargo style floor.
    Post by Russell Mon Dec 06, 2021 8:58 am
    I also put some material on the door at the bottom under original Chrome strip and top to match the side window frames, small rubber edging around the wood also.
    Russell's '66 GMC HandiVan Door110
    Russell's '66 GMC HandiVan Door10
    savage, dix, gmytych and vanny like this post
    Post by vanny Mon Dec 06, 2021 2:38 pm
    Looks Great Russell! I like the look of the material at the bottom of the door and it should probably extend the life of the wood panel as well. Feet tend to scratch the wood up so that padding should help with that…
    savage and gmytych like this post
    Post by Russell Thu Feb 03, 2022 7:56 am
    vanny wrote:Looks Great Russell! I like the look of the material at the bottom of the door and it should probably extend the life of the wood panel as well. Feet tend to scratch the wood up so that padding should help with that…
    I learned from my other Van the bottom of the doors had scuff marks from holding it open with my foot. The material will help these panels to survive.
    Post by Russell Wed Jul 20, 2022 7:53 am
    Russell's '66 GMC HandiVan 11010
    Russell's '66 GMC HandiVan 10910
    Russell's '66 GMC HandiVan 10210
    Russell's '66 GMC HandiVan 10310
    I haven't posted in a while, I decided to paint over the blue and went to grey, I think it gives more of a user friendly look.
    Post by vanny Wed Jul 20, 2022 8:00 am
    Is it for sale Russell? And if so, what are you asking for this great looking Van?
      Current date/time is Tue May 07, 2024 3:10 pm
