    Oil filter sportvan 108 Whit 307
    marco_chevy
    marco_chevy
    Number of posts : 151
    Registration date : 2015-05-23
    Oil filter sportvan 108 Whit 307 Empty Oil filter sportvan 108 Whit 307
    Post by marco_chevy Mon Apr 13, 2020 11:20 am
    Hi. I have a 1969 sportvan 108 Whit a v8 307. Casting is 3956632 and need to change oïl .
    Past Time i changed it , i put Napa 1143 (pf-141) element that go in canister ( 2 pièces )
    Oil filter sportvan 108 Whit 307 Ce136b10
    But when guys search Whit my van model , They always give me standard complete filtre ( 1 pièce)
    Ao its 1143 that go 1969 307 v8 or a
    Number of posts : 2626
    Oil filter sportvan 108 Whit 307 Empty Re: Oil filter sportvan 108 Whit 307
    Post by savage Mon Apr 13, 2020 1:15 pm
    When my 68 G-20 had the 307 stock motor it had spin on filter.
    It was stock as far as I know(came from Mark(108VanGuty) from CA as a Vanataner
    Oil filter sportvan 108 Whit 307 Img_0624
    Oil filter sportvan 108 Whit 307 Img_0625
    Full of parts(& in motor in parts)
    Post by donivan65 Mon Apr 13, 2020 5:56 pm
    You got the old type canister oil filter,,,,,its just the cartridge that fits in a can,has a big O-ring for the engine end, maybe a washer for the bolt,,,,,,,,,like Studebakers used,,,,,,they they got rid of that type and converted over to spin on type,,,,,,so whats your question,,,they cant figure out what to order?    Its an AC Delco PF 141,,,,have them do a crossover search of that number and you will see what Fram, Purulator, Hastings  and all other companys call that filter,,,,,
    Oil filter sportvan 108 Whit 307 Pf14110
    Post by donivan65 Mon Apr 13, 2020 10:25 pm
    ,,,and they make adapters to change the engine to a ,,,,,,,,,normal,,,,,,,,oil filter.
    Oil filter sportvan 108 Whit 307 Fill10
    marco_chevy
    marco_chevy
    Post by marco_chevy Wed Apr 15, 2020 8:31 pm
    Pf-141 or Napa 1143 or double price of standard filter.
    So, Whit is the best ? Keep the original one or buy the adapter and put spin-On filter?
    One is better than other ? May be easier change spin-on ! Not easy Whit original to have no oil drop anywhere Sad.
    Post by donivan65 Wed Apr 15, 2020 10:10 pm
    If I had a van,,,,,,I would surely stock up on these $5 Fram filters from RockAuto,,,,,,,you can do whatever you want to our vans,,,,,,have a shop do it,,,,,,whats the interval,,,6000 miles,,,,,,with Canadian winters,,,,whats that,,,,,,3 years,,,,,,,that big O ring sure seems to cause people problems,,,,,,some people say they have to pull the bypass valve off to get it out,,,no wonder they started building engines with the spin on filter,,,,,,,,Corvettes use that same filter,,,,,,and boy,,,,,they sure rip them guys off for that filter,,,,,,
    Oil filter sportvan 108 Whit 307 Fill110
    Post by donivan65 Wed Apr 15, 2020 10:24 pm
    Of course if you hurry,,,,,,you can get this AC filter and brag that you got a Corvette oil filter on your van,,,,,,but if its been sitting in that box for 50 years,,,,,it will probably fall apart and plug up your oil passages and burn up your engine,,,,
    ,Oil filter sportvan 108 Whit 307 Fil210
    marco_chevy
    marco_chevy
    Post by marco_chevy Thu Apr 16, 2020 4:15 am
    Canister or spin-On, its the same result ? same filtration ?
    I change oïl 1 Time by 2 years. Not a big problem . I make about 2-3000 miles per years.
    And i didnt see oil link by the oil filter , so not a problem !
    Post by donivan65 Thu Apr 16, 2020 11:54 am
    They both do the same thing,,,,,they just figured out how to make it easier to change and less likely to leak when they invented the spin on,,,,,,,,,I would have to say those cartridges will be getting harder to find and more expensive in the future,,,,,,just have a plan on where to buy that adapter when you finally need one,,,,,
    marco_chevy
    marco_chevy
    Post by marco_chevy Thu Apr 16, 2020 12:26 pm
    All adapter i found, its write ‘ Notes: Use a Fram FRM-PH5 filter or equivalent. Must be used with the original bypass valve part number 5573979.
    Where it is ?
    Post by donivan65 Thu Apr 16, 2020 1:57 pm
    its what that big bolt screws into in the engine,,,,,its what the top of the filter presses against,,,,,probably held  onto the engine with two bolts,,,,,,
    marco_chevy
    marco_chevy
    Post by marco_chevy Sun Apr 19, 2020 7:41 pm
    I put back the original one. I change it only each 2 years. So its ok like that and still original Smile
      Current date/time is Thu May 02, 2024 6:11 pm
