    1966 Dodge A100 $10000 (FLA)
    a100_Bubba
    a100_Bubba
    Number of posts : 2650
    Registration date : 2012-03-08
    1966 Dodge A100  $10000  (FLA) Empty 1966 Dodge A100 $10000 (FLA)
    Post by a100_Bubba Sun Apr 14, 2019 2:26 pm
    https://orlando.craigslist.org/cto/d/orlando-1966-dodge-a100-truck-300hp/6863763847.html
    1966 Dodge A100
    fuel: gas
    title status: clean
    transmission: manual
    1966 Dodge A100 pick-up truck. Is there anything cooler? This one makes 300 horsepower! Totally custom, lots of NOS parts.
    Watch the videos below:
    https://youtu.be/PPf3yv-cXdQ
    https://youtu.be/cWHX7ZgicgU
    The Build:
    225 Slant Six bored .040"
    .010" on the crank and rods
    Clevite 77 bearings
    Hastings Rings
    ARP studs
    Melling High Volume Pump
    One Piece Rear Main Seal Upgrade!
    head milled .125" !!! Yes! 1/8" !!!
    Stainless oversized racing valves 2.08" / 1.44"
    Comp Triple Springs
    Victor Head Gasket
    Copper Intake/Exhaust gaskets
    Comp Kustom Cam
    Comp Pushrods
    Comp Locks and Retainers
    Comp Lifters
    New pan, dipstick, pickup tube
    Clifford Ceramic Coated Long Ram Intake Manifold
    Clifford Ceramic Coated Headers
    New Ceramic Coated Valve Cover
    New Weber Carb
    Pertronix Ignition
    New Distributor
    Kustom Taylor Wires
    Denso Iridium Plugs
    New fuel pump, sender, and filters
    Kustom Urethane Engine Mount
    20AN Water Pump Block Off from Australia
    BMW Electric Water Pump
    Kustom German Speed Controller for pump and fans1966 Dodge A100  $10000  (FLA) 00V0V_1eEjjToN105_600x450
    Billet and Air Cooled Custom Flywheel from Australia
    SFI Billet Balancer
    New 100 Amp Mini Alternator
    Quicktime Bell Housing
    Ceramic Racing Clutch
    Kustom McLeod throwout bearing
    McLeod Hydraulic Clutch Master
    Aluminum Racing Radiator
    Dynomax Performace Muffler
    New Seats, brackets, hardware
    New Doghouse
    NOS steering wheel
    NOS door handles
    NOS Weatherstrips (vent windows)
    NOS Headlamp Bezels
    NOS Parklamps
    NOS FARGO Emblems
    Rust-free doors
    NOS Bedsides
    NOS Doglegs
    NEW Floors installed
    New lower interior cab corners done
    NOS Bumper Brackets
    Kustom Tubular Front Bumper
    New Rader Wheels 18"
    New BFG Sport Comp Tires
    New Disc Brake Conversion
    New Wilwood Hubs
    New Calipers, Brackets, Hardware
    New ARP Wheel Studs
    New Raybestos Pads
    New Bronco Sway Bar Upgrade with links
    NOS belly pan
    NOS Tail Lamps
    NOS Antenna
    NOS Gas Pedal
    Etc............Etc.................Etc.........
    If you have read this far, you know this truck has $20k in just parts invested. It needs a new wiring harness. It is included in the sale. This thing hauls ass and has the best of everything.
      Current date/time is Sat Apr 27, 2024 2:27 pm
