https://orlando.craigslist.org/cto/d/orlando-dodge-a100-truck-1966/6776002597.html
1966 Dodge A100 Truck
drive: rwd
fuel: gas
odometer: 150
title status: clean
transmission: manual
type: pickup
1966 Dodge A100 pick-up truck. Is there anything cooler? This one makes 300 horsepower! Totally custom, lots of NOS parts.
The Build:
225 Slant Six bored .040"
.010" on the crank and rods
Clevite 77 bearings
Hastings Rings
ARP studs
Melling High Volume Pump
One Piece Rear Main Seal Upgrade!
head milled .125" !!! Yes! 1/8" !!!
Stainless oversized racing valves 2.08" / 1.44"
Comp Triple Springs
Victor Head Gasket
Copper Intake/Exhaust gaskets
Comp Kustom Cam
Comp Pushrods
Comp Locks and Retainers
Comp Lifters
New pan, dipstick, pickup tube
Clifford Ceramic Coated Long Ram Intake Manifold
Clifford Ceramic Coated Headers
New Ceramic Coated Valve Cover
New Weber Carb
Pertronix Ignition
New Distributor
Kustom Taylor Wires
Denso Iridium Plugs
New fuel pump, sender, and filters
Kustom Urethane Engine Mount
20AN Water Pump Block Off from Australia
BMW Electric Water Pump
Kustom German Speed Controller for pump and fans
Billet and Air Cooled Custom Flywheel from Australia
SFI Billet Balancer
New 100 Amp Mini Alternator
Quicktime Bell Housing
Ceramic Racing Clutch
Kustom McLeod throwout bearing
McLeod Hydraulic Clutch Master
Aluminum Racing Radiator
Dynomax Performace Muffler
New Seats, brackets, hardware
New Doghouse
NOS steering wheel
NOS door handles
NOS Weatherstrips (vent windows)
NOS Headlamp Bezels
NOS Parklamps
NOS FARGO Emblems
Rust-free doors
NOS Bedsides
NOS Doglegs
NEW Floors installed
New lower interior cab corners done
NOS Bumper Brackets
Kustom Tubular Front Bumper
New Rader Wheels 18"
New BFG Sport Comp Tires
New Disc Brake Conversion
New Wilwood Hubs
New Calipers, Brackets, Hardware
New ARP Wheel Studs
New Raybestos Pads
New Bronco Sway Bar Upgrade with links
NOS belly pan
NOS Tail Lamps
NOS Antenna
NOS Gas Pedal
Etc............Etc.................Etc.........
If you have read this far, you know this truck has $20k in just parts invested. It needs a new wiring harness. It is included in the sale. This thing hauls ass and has the best of everything.
You will have the only one at your local cruise night!!!!!!!!!
No tire kickers, trades or stories please. Serious buyers only 🤑
$15,000 USD
drive: rwd
fuel: gas
odometer: 150
title status: clean
type: pickup
The Build:
Clevite 77 bearings
Hastings Rings
ARP studs
Comp Triple Springs
Victor Head Gasket
Comp Kustom Cam
Comp Pushrods
Comp Lifters
New Weber Carb
Pertronix Ignition
New Distributor
Kustom Taylor Wires
Denso Iridium Plugs
SFI Billet Balancer
New Doghouse
NOS steering wheel
NOS door handles
NOS Headlamp Bezels
NOS Parklamps
NOS FARGO Emblems
Rust-free doors
NOS Bedsides
NOS Doglegs
NOS Bumper Brackets
New Wilwood Hubs
New ARP Wheel Studs
New Raybestos Pads
NOS belly pan
NOS Tail Lamps
NOS Antenna
NOS Gas Pedal
$15,000 USD
