https://detroit.craigslist.org/okl/cto/d/1966-dodge-a100-ca-window-van/6580946741.html
1966 Dodge A100
condition: good
cylinders: 6 cylinders
drive: rwd
fuel: gas
paint color: white
title status: clean
transmission: automatic
..Very rare..225 slant 6 Auto,50K on rebuild (94')..Bought this in Pasadena Ca. in 1991 from brother of orig. owner..spent one year in Brooklyn NY (2003) after job switch..stored indoors since..in the middle of resto in 2005,entire bed and outside up to the cab was primed when man working on it had a major health issue and closed his shop..Front drivers side corner was hit in a parking lot,pushing the lower hinge back 1/8"..guy was in the middle of that repair when he had to stop (after cutting blinker frame out to pull hinge)..frame is straight..everything is intact..underneath was completely painted with DTM Por 15 and is very clean.Drivers side rear had lower belly crease,which was pro repaired also..everything otherwise is orig..needs new front flat glass (I do have new window channel) seats need redone,rear upper vent section and lower right hinge mount on rear right door need welding,along with aforementioned front blinker frame..and I can't find 4 hinge pins and 2 inner door handles..I have new chrome bumpers,headlight frames,letters,lenses,door seals and more.. and new outer rocker skins from years of Mopar Nats. visits..motor runs strong,727 trans. solid as a rock..lots of old maintainance records too..2 rear windows scratched by NYC idiots and one by steel hauler..never in a moving accident,and was Wimbledon white..this is a project,but it is very manageable Auto shop 101 stuff and the price reflects that.Priceless when finished..Van is in 10/Haggerty area of Novi..phone calls only..$4800 show contact info
..no yahoo's please..Thanks Dave
1966 Dodge A100
condition: good
drive: rwd
fuel: gas
paint color: white
title status: clean
