Van dodge A100 1965 - $6500
1965 Dodge A100
fuel: gas
title status: clean
transmission: automatic
I am offering my 1965 Dodge A100 shorty custom panel van. It is a very special rig. I have kept the original paint that was done in the 70s. It was first blue and then became an Audio demonstration van. It was painted with the most amazing yellow metal fleck laquer. The special super amazing aspect is the double airbrush space theme on each side featuring the starship enterprise. It is just sublime. The condition of the paint is fair. It needs to be painted if you can. I did not have the heart. It gets so many comments and people photograph it wherever I go. It has the slotted mags. I drive it daily.
It has a 318 v8 with a carter two barrel. Even as stock and dialed down as the motor is, it will still lay rubber. I built it for reliability as I was traveling and camping in it. I put an automatic fuel pump and electronic fan in it so it cools well, The LA motor has 25,000 ish miles. the 904 three speed transmission is fresh. maybe 3 or 4 thousand on that professional rebuild.
The transmission needs a new mount to replace the sling and there is a flat spot in the steering box.
I just repacked the wheel bearings, greased everything and there are new fluids and oils all around. there are airbags in the back that really tightens it up. It has updated very comfy toyota seats and a new carpet and wood interior. I am pretty darn firm at 6200. you may call me and talk to me about it.
https://santabarbara.craigslist.org/cto/d/vintage-van-dodge-a/6582076168.html
1965 Dodge A100
fuel: gas
title status: clean
