Does anyone know of a source for new replacement wheel hubs for the A100?
I don't need any yet, but would like to know before I do need them.
Gileadgarage wrote:They are hard to find, but not sure if they are specific to the A100. Take extra care when you do your disc swap, make sure you cut around the swaged on studs and don't just pound them out. I used a 3/4 hole saw which worked fine as the stud tapers out a bit at bottom. Don't go all the way through to hub.
Once you cut the sweged area, the studs come out pretty easy, but do support the bottom of hub so it does not bend. When pressing the new larger studs in, make sure you have the hole size right. You can crack the hub if there is too much interference!
Any pics of the GTX in your sig?
Mark
